- Joined
- Aug 2, 2020
- Messages
- 688
- Likes
- 566
Dutch and Dutch would like a word.8k is insane for a bookshelf, regardless of how good you make the drivers its still not going to compare to even cheaper large floorstanders in several areas.
Or a lyricDutch and Dutch would like a word.
The (TPCD) TexTreme carbon fiber used in our midrange drive units is also the key to the performance of our woofers, resulting in lighter-than-air dynamics and the impact you expect in a flagship Speaker that can play down to 20Hz in-room.
Frequency Response | 80-20kHz |
I want some with CarbotaniumSpeaker technology
Our most advanced speaker to date! When the highest fidelity is what matters most. Featuring our proprietary DPC-Array controlling Mid/High frequencies and centered by our finest 28mm Beryllium dome and dual 28mm TPCD ultra-lightweight domes.www.perlistenaudio.com
Frequency Response 80-20kHz
20Hz or 80Hz? Which one is true?
However, I liked the phrase “lighter-than-air dynamics”. Give that marketing guy a pay rise
HeliumSpeaker technology
With all the other companies having price increases, I emailed Perlisten to verify. The updated MSRP (as of August 2021) is ~$8000/pair.
If we're going down this rabbit hole, the argument regarding the point of diminishing returns apply. So do we stop investigating expensive "state of the art" speakers simply because they cost far above the point of diminishing returns? What about the Perlisten floorstanders that cost $18,000 a pair - is this too "insane"? Certainly for a middle class hard working family, but for the single bachelor cosmetic surgeon in Newport Beach, it's likely too cheap if he wants to impress his friends who own Wilsons.8k is insane for a bookshelf, regardless of how good you make the drivers its still not going to compare to even cheaper large floorstanders in several areas.
Yes, the 80Hz bass extension is quite puzzling to me too. I'll give them 100Hz for the smaller S4B bookshelves and very curious how @hardisj measurements will show, but for the floorstanders even at +/- 1.5dB isn't 80Hz a bit pedestrian?Speaker technology
With an in room prediction of an F10 at 30hz and a shallow slope, it's should do well. The distortion numbers to hit THX Ultra should be good.Yes, the 80Hz bass extension is quite puzzling to me too. I'll give them 100Hz for the smaller S4B bookshelves and very curious how @hardisj measurements will show, but for the floorstanders even at +/- 1.5dB isn't 80Hz a bit pedestrian?
Thanks for the clarification. I should also have added that those buying the Perlisten for "high end home theater" will always have it matched to a subwoofer which would cut off at 80Hz anyway!With an in room prediction of an F10 at 30hz and a shallow slope, it's should do well. The distortion numbers to hit THX Ultra should be good.
It turns out it's the best bookshelf speaker in the world objectively. and would give 99% of floorstanders a run for their money. Thanks @hardisj for another amazing review: https://www.erinsaudiocorner.com/loudspeakers/perlisten_s4b/
From what has been measured, i think it is Objectively the best in my opinion.Not sure it's the best bookshelf?
F10 at 40Hz is hardly no bass. It's a sealed design with a slow roll-off.No bass
If someone wants SOTA performance in a bookshelf sized format, this is the right tradeoff IMO.From what has been measured, i think it is Objectively the best in my opinion.
The 8341A is a contendor for linearity, but falls short in comparision in terms of output imo.I think Dutch & Dutch, Kii, Genelec and some others are all there. Plus they have amplifiers built in. At this level it is hard to say any one of them is "best" because it depends more on what trade-offs you care about to make that determination. But they are certainly quite excellent even if they are not unequivocally "best".
If you want the best possible bass, you’re going to want multiple subwoofers, optimally placed and room optimized anyway. Considering the target market of high end home theater users, this seems intentional.
This level of performance is incredible, and can hold up to similarly priced high end designs.
It’s amazing they’re able to do this with a passive design!
I don't mean to criticize the speaker by asking this (or you either). But what is different about the 12dB rolloff compared to other sealed speakers (or port plugged)? Why is it important to you to cross at 80Hz compared to another frequency? Maybe 80Hz is optimum in some way I'm not aware of? I thought 80Hz was typical but I have not been aware that it is optimum in some way.you know what really pushed it over the top for me? The F3 is almost at 80Hz. that means integration with subwoofers would be a breeze even without a high-pass filter.
This is the first speaker in my life that i have seen that is optimally designed for an 80Hz crossover with a subwoofer.
Its a good optimum and standardised by THX.I don't mean to criticize the speaker by asking this (or you either). But what is different about the 12dB rolloff compared to other sealed speakers (or port plugged)? Why is it important to you to cross at 80Hz compared to another frequency? Maybe 80Hz is optimum in some way I'm not aware of? I thought 80Hz was typical but I have not been aware that it is optimum in some way.
