PEQuestrian
- Joined
- Aug 25, 2024
- Messages
- 18
- Likes
- 42
Heard a pair of these today in a treated 15x20 room about 6.5 feet apart, pulled out about 6 or 7 feet from the back wall. No room correction was used. They throw an incredibly wide soundstage, to the point where the outer edges appeared to come from the upper left and right corner of the room. Standing further back, it sounded like there were side surrounds playing. Focusing on specific instruments like hi hats, you can hear that the midranges and tweeter are sitting in the middle of the vertical driver stack when you're sitting fairly close and at higher volumes, they completely over-pressurized the room so this speaker might be a bit wasted in most people's living rooms. Another observation that they need a good amount of distance and room width to shine was how sensitive they were to toe-in. Like no other speaker I've heard, the sound (at 6 feet away) changed so much it was baffling. Very unforgiving sweet spot at that distance. With just a bit of toe-out beyond being directly pointed at your years, the phantom center became audibly separated which I bet is much less of a problem further away but anyone with an MLP 6 - 8 feet out considering these should be aware of that.
My main negative though was the lacking lower bass extension. The low end really sounds rolled off early, which became very clear when listening to a couple of other speakers back to back hooked up to the same sources. I get that there may be a conscious trade-off design wise but personally, I have a really hard time justifying spending over $10K on a huge speaker and still needing subwoofers to hear acoustic or e-bass notes not disappear at the lower end. There's a difference between tight bass and rolled off bass.
I do wonder how the Arendal 1528s compare to these in terms of bass extension.
