Anton S
What perceptual differences do you notice when listening to music sighted versus unsighted, i.e. eyes open vs. closed? I have long contended that humans are primarily visual creatures. At least I am. Given a bimodal or multimodal sensory experience that includes both auditory and visual inputs, each will affect the other to a certain extent, but the visual generally contributes most to my experience.
This phenomenon is apparent whenever I relax and listen to music in a focused manner. It’s a very different experience for me when my eyes are open than when they are closed. With them open, I see my front equipment arranged a plane flanking my screen and their exact locations across my field of view. Although my music sounds fine in this case, the perceived front-to-back stage depth seems somewhat shallow, because my eyes are processing that flat plane of equipment. Also, left-right staging appears a little narrow, because my L/R speakers are relatively close together compared to my listening distance, and I can visually locate each component in front of me very precisely. Conversely, with my eyes closed and the visual input removed, left-right staging appears to broaden, and perceived front-back depth is enhanced, because I’m not seeing that flat plane of equipment before me. These perceptual changes do not occur immediately or all at once, because my memory of the visual stimulus lingers for some time, but after a short interval and gradually.
Curious about this phenomenon, I did some poking around and discovered several studies that looked at mixed-modality sensory inputs. The two cited below were generated from two very different perspectives, but drew congruous conclusions. The first, from the National Library of Medicine, discusses mixed-modal inputs from a medical perspective, and the second, from the US Army Aeromedical Research Laboratory, investigates the phenomenon with respect to HMD’s (Helmet Mounted Displays). However, both detail the “ventriloquism effect” and the impact of visual stimuli on audition, which I believe correlates well with the perceptual changes that I described above.
I believe this phenomenon is reasonably universal, and that every sighted human with normal hearing perceives similar changes so some degree. If you’ve previously noted this phenomenon yourself, please share below. Unfortunately, if not and you’ve read this far, it’s probably too late for you to offer an unbiased assessment. Future perception will likely be influenced by expectation.
I’ve noticed another mixed modal sensory phenomenon, which I haven’t yet researched at all, but thought I’d mention in passing, just to see if anyone else has previously noted it. This one involves a physical/tactile element, rather than a visual one, in addition to the auditory one. I’ve worn glasses for many years – so long that I am unaware of the fact most of the time. However, I often remove them when relaxing to music, since there’s really no need for visual input. But as soon as I remove my glasses, the auditory experience immediately changes, even when my eyes are completely closed. The music sounds clearer and more immediate to me. The closest analogy I can think of is the difference between looking at a room through a window and being in the room. Weird, huh?
Although, as I said above, I haven’t investigated this phenomenon at all, I suspect that there are both physical and psychoacoustic aspects to it. First, my lenses and frames undoubtedly alter the sound reaching my ears. And second, the removal of constant pressure on my temples and the bridge of my nose alters my perspective by removing that tactile input, eliminating a subconscious distraction from the auditory experience. Has anyone else who wears glasses ever noticed a similar change?
Interactions of Auditory and Visual Stimuli in Space and Time
AUDITORY-VISUAL INTERACTIONSI believe this phenomenon is reasonably universal, and that every sighted human with normal hearing perceives similar changes so some degree. If you’ve previously noted this phenomenon yourself, please share below. Unfortunately, if not and you’ve read this far, it’s probably too late for you to offer an unbiased assessment. Future perception will likely be influenced by expectation.
