I have a couple of questions regarding when to apply PEQ filters and I find conflicting information online. Perhaps someone here can help me! Thank you in advance for your help!
1. Should I PEQ my subs before of after running Audyssey? I've been doing it after. My thought process was to let the automatic system do the best it can first and then manually tailor things to my preference.
2. When running multiple, subs should I run a sweep with each sub individually (one sub on the other off) and set the PEQ filters for each sub individually or should I run a sweep with both subs on and PEQ them together?
3. Should the PEQ filters for both subs match or can each sub have its own filters?
*4. (Bonus Question) For Audyssey, at what frequency should I cut off the automatic adjustments? I've been cutting off the filter range at 500Hz, but different sources online give different opinions. Some say 200Hz. Some say no cut off. Any thoughts?
Thanks.
Thanks.
