Peak Amplification AM-400C2G GAN amp module
Status
Not open for further replies.
The testing has already been completed and documented in the datasheet. Unless someone has third party tests of the module showing different data, the argument is over.
Hardly. The fact that the GAN ICs are fine doesn't mean the rest of the amp is. Over time, the rest of the components will heat up. What if you put them in an enclosure? Caps specifically will age rapidly when subjected to excessive heat. Whether a fully functioning commercial design would be able to reliably run for years without a heatsink will very much depend on the rest of the design and enclosure integration.
We have seen Purifi modules running their rated power continuously (and I mean continuously, no tricks) at 20kHz at real-world conditions (with heatshinks of course, the Apollon Audio build)
Until we see something similar there the argument is far from over. Moreover without heatshinks as they claim.
Sure, we have seen tiny modules running their rated with the tiny onboard heatshinks, I have couple here, icepower 300a2 ones.
They don't even get warm with music.
Tasking them with my woofer section however and with certain works I can make them run at 65° C easy.
We can't talk in general, application is the key.
My "ancient" Hypex UcD400LP (ELAC amplifier) delivers about the same amount of power in a very small package:
Of course the THD+N is worse but I predict, that it would be almost impossible to detect in an ABC test. Sometimes it seems to me, that we should concentrate on stability, reliability and longevity of power amps instead of running circles around a questionable "improvement" like GAN transistors.
Since the entire BOM of the board is listed in the datasheet, it makes it easy to do a real-world comprehensive evaluation on longevity of the board. I ran one and results are below:
To assess whether the other components on the AM-400C2G module (a copy of the REF_Audio_GaNb_750W reference board) are likely to suffer from a shortened life due to a 60°C internal temperature of the PCB during typical music playback (47 W output, as per the user guide), we need to evaluate the thermal environment, the components’ temperature ratings, and their expected lifetimes. The user guide specifies a PCB temperature of 60°C for the 1/8th power test (47 W, 2 Ω, ±36 V, no heatsink, 30 minutes), which we’ll use as a reference for the thermal conditions affecting all components.
Step 1: Understanding the 60°C Temperature Context
• Reported temperature: The user guide (Table 6, Section 7) states a maximum PCB temperature rise to 60°C for 47 W output over 30 minutes. This is likely the surface or case temperature of the PCB, not the junction temperature of the GaN transistors (IGB110S10S1) or other components.
• GaN transistor junction temperature: The IGB110S10S1 has a maximum junction temperature (Tj max) of 150°C. The junction temperature is higher than the PCB temperature due to thermal resistance (RθJA ≈ 40–50°C/W for the 3x3 mm PQFN package, per typical GaN transistor specs). For 47 W output, dissipating ~2.06–5.22 W total (as calculated previously), the per-transistor dissipation is low (e.g., ~0.5–1.3 W per transistor, assuming four transistors in the half-bridge topology). This results in a junction temperature rise of ~20–65°C above the PCB, yielding Tj ≈ 80–125°C, well below the 150°C limit.
• Implication: The 60°C PCB temperature indicates a benign thermal environment for the GaN transistors, but we need to assess whether this temperature affects other components’ longevity.
Step 2: Key Components on the Board
The bill of materials (Section 11 of the user guide) lists various components, including capacitors, resistors, diodes, ICs, and connectors. We’ll focus on components most susceptible to temperature-related degradation:
• Capacitors: Includes ceramic (e.g., X7R, C0G), aluminum electrolytic (e.g., 470 µF, 63 V), and film capacitors (e.g., 0.1 µF, 100 VDC). Electrolytic capacitors are particularly sensitive to temperature.
• Resistors: Mostly SMD (0603, 0805, etc.), rated for high temperatures (typically 125–155°C).
• Diodes: Zener, Schottky, and standard diodes (e.g., 1N4148W, MMSZ5245B), typically robust up to 150°C.
• ICs: Includes the IRS20957S audio controller (Tj max 150°C), 1EDN7116U gate drivers (Tj max 150°C), and OPA1655 op-amps (Tj max 150°C).
• Other: Inductors (e.g., CPD1521C-100M), connectors, and transistors (e.g., MMBT5551, Q6–Q8).
Step 3: Temperature Impact on Component Lifespan
• Electrolytic Capacitors (e.g., C4, C10: 470 µF, 63 V):
• Temperature sensitivity: Electrolytic capacitors are the most temperature-sensitive components. Their lifespan typically halves for every 10°C increase above a reference temperature (e.g., 85°C or 105°C), per the Arrhenius equation.
• Typical ratings: The user guide specifies 63 V electrolytic capacitors, likely rated for 85°C or 105°C (common for SMD aluminum capacitors). At 60°C PCB temperature, the capacitor’s internal temperature may be slightly higher (e.g., 65–70°C due to self-heating and proximity to other components).
• Lifespan estimate: For a 105°C-rated capacitor with a 2,000-hour life at 105°C, the lifetime at 70°C is extended significantly:
• Lifetime multiplier ≈ 2^((105–70)/10) ≈ 2^3.5 ≈ 11.3.
• Lifetime ≈ 2,000 × 11.3 ≈ 22,600 hours (~2.6 years continuous operation).
• For 85°C-rated capacitors, lifetime at 70°C is ≈ 2^((85–70)/10) ≈ 2^1.5 ≈ 2.8, or ~5,600 hours (~7.5 months continuous).
• Assessment: At 60–70°C, electrolytic capacitors operate well below their rated temperatures, ensuring a long lifespan (years for 105°C-rated, months for 85°C-rated under continuous use). Music playback is intermittent, further extending life.
• Ceramic and Film Capacitors:
• Temperature ratings: X7R/C0G ceramics and film capacitors (e.g., C71A, C71B: 0.1 µF, 100 VDC) are rated for 125°C or higher. Their degradation is minimal at 60°C, with lifetimes exceeding decades.
• Assessment: No significant lifespan reduction at 60°C.
• Resistors:
• Temperature ratings: SMD resistors (e.g., 0603, 0805) are typically rated for 125–155°C (per IPC standards). At 60°C, they operate far below their maximum, with negligible degradation.
• Assessment: Resistors are unaffected by 60°C, with lifetimes well beyond typical application needs.
• Diodes:
• Temperature ratings: Diodes like 1N4148W and MMSZ5245B have Tj max of 150°C. At 60°C PCB temperature, their junction temperature remains low (e.g., <100°C), as they handle low currents in this design.
• Assessment: Diodes are robust at 60°C, with no significant lifespan impact.
• ICs (IRS20957S, 1EDN7116U, OPA1655):
• Temperature ratings: All have Tj max of 150°C. The IRS20957S, which controls OTP, operates at ~60–80°C junction temperature (based on thermal resistance of 115°C/W and low power dissipation). Gate drivers and op-amps similarly operate well below their limits.
• Assessment: ICs experience minimal stress at 60°C PCB temperature, ensuring long-term reliability.
• Inductors and Connectors:
• Inductors: The Class-D inductors (L3A, L3B) are designed for high-current audio applications, typically rated for 125°C or higher. At 60°C, they are unaffected.
• Connectors: PCB connectors (e.g., X4, X5) are rated for 85–125°C, with no degradation at 60°C.
• Assessment: Both are robust at 60°C.
Step 4: System-Level Considerations
• Thermal distribution: The 60°C PCB temperature is a maximum surface measurement, likely near the GaN transistors or power stage. Other components (e.g., capacitors, ICs) may experience slightly lower temperatures due to their placement or lower power dissipation, reducing thermal stress.
• Intermittent use: Music playback involves dynamic power levels, with average operation well below 47 W for casual listening. This reduces thermal exposure compared to the 30-minute test, extending component life.
• Protection mechanisms: The IRS20957S’s OTP (activates at ~150°C junction) ensures the module shuts down if any component approaches critical temperatures, protecting the system.
• GaN advantage: The CoolGaN™ transistors’ high efficiency (95.8% at 47 W) and low thermal output (2.06–5.22 W total heat) minimize heat transfer to other components, keeping the PCB temperature low.
Step 5: Comparison to Higher-Power Scenarios
The user guide’s thermal data for peak power (Table 4, Section 7) shows:
• At 375 W x 2 (2 Ω, ±36 V), Tcase = 150°C for >1 minute, no shutdown.
• At 240 W x 2 (4 Ω, ±40 V), Tcase = 71°C for >1 minute, no shutdown.
These higher-power cases push components closer to their thermal limits, but the 60°C at 47 W is far more benign. Even electrolytic capacitors, the most vulnerable components, operate comfortably at 60–70°C, with lifetimes extended significantly compared to higher-temperature scenarios.
Conclusion
Based on the data from the Infineon REF_Audio_GaNb_750W user guide, the 60°C PCB temperature during typical music playback (47 W output) is unlikely to cause a shortened lifespan for other components on the AM-400C2G module. Key findings:
• Electrolytic capacitors: At 60–70°C, 105°C-rated capacitors have lifetimes of ~22,600 hours, and even 85°C-rated ones last ~5,600 hours, sufficient for years of intermittent music playback.
• Other components: Ceramic/film capacitors, resistors, diodes, ICs, inductors, and connectors are rated for 125–150°C, operating far below their limits at 60°C, with negligible degradation.
• System design: The GaN-based design’s high efficiency and OTP ensure minimal thermal stress, and the 60°C PCB temperature is well within safe operating conditions for all components.
No components are likely to suffer from a shortened life at 60°C, as this temperature is well below their rated maximums, and the module’s design optimizes thermal management for reliable, long-term operation in music playback scenarios.
• Resistors:
• Diodes:
Conclusion
The above only addresses the 47W case without the peaks.
The whole point of the 1/8 power rating is that it includes the rest 7/8 for peaks.
Lots of use cases to that.
On top of that, temp variations (between average and peak) have their own implication and the equation has to include the ability to dissipate heat over time (at a chart) .
Your AI-generated analysis does not take the enclosure thermal design into account, and therefore, it is inconclusive. A 60 °C temperature of a bare PCB with lots of air around it in a lab, does not mean it's going to be still 60 °C when confined in a tiny enclosure with an SMPS added. Never mind that you'll need to account for various environmental factors. In some places on earth, it's much hotter on average. People cram these cases in small cabinets, etc...
47W is based on the maximum continuous output capability of the board. And this isn’t even with music. It’s with a steady sine wave. With music the output will be much less. And it also assumes full blast will be the only level that anyone ever listens to the amp at. Sometimes people listen to music other than Slayer turned up to 11 100% of the time.
It assumes that the manufacturer using the design has a few brains in his head and uses an appropriate chassis to house the unit. Probably something like Peak is using. Ventilated on bottom and top. Even with your other caveats, the 47w continuous test with a sine wave far exceeds what the real world continuous music output will subject the amp to.
Yes, we can't compare a sine with the additive spectrum power (well, we can, imagine the -10dB mandatory reduction of a WN test signal after a sine test for example , but lets leave that) .
But we do know demanding music which can drain any ounce of power .
Use cases are thousands.
At 91° C, sure.
The thing is that we have to maintain the 60° C mark for home use.
(and at 91° C for a long period rest of the components won't be happy)
Depends where that is measured - if it is silicon junction temperature - ain't a problem. Even transistor case temperature probably fine also. It depends on what temperature local heat sensitive components (electrolytic capacitors for example) get to.
There’s 9 cheap electrolytic caps on the board in total. In 15 years you might need to spend 75 cents recapping the amp if the design doesn’t use a heatsink.
We talk pure fantasy here of course, the amp will need to be in an enclosure so some heatshinking will be there at either case, helping with the PSU too as usual, the works.
Someone will need to be mad not to use it.
It's the claims that are strange, hence the discussion.
The board is literally designed from the ground up to not use heatsinks. Theres no place to even attach heatsinks to. The board sits on stand-offs and you mount it in the case. With air space all around it. 80% of the heat dissipated from the module comes from 4 tiny 3x3mm GaN transistors. They’re like the size of grains of rice. The copper backplane of the board is the heatsink for them.
So, we can't apply thermal management other than active even if we wanted to?
That's a serious compromise, can't be right.
Say,I want to put it in a sub banging EDM (which includes WN) ,this way I couldn't.
GaN's potential is high power with little losses ,other than that would defeat the purpose. For low power like 100-200W there are other solutions, rock-solid over time.
It's the over 300W-500W area that is interesting.
If you buy an amp using these modules I suppose you could try to DIY some sort of heatsink onto those tiny transistors. But since the electrolytic caps are the only parts even remotely sensitive to heat, might as well just heatsink the caps. Install a liquid cooling system for the caps only. But something tells me the engineers behind the board likely understand how hot the caps get and if the design compromises the cap life or not. So maybe do your own testing of cap temps first.
Status
