Not "for whatever reason". This just is the lack of proper level match, and as such the comparison is, unfortunately, not relevant.For whatever reason its sound through the Nova feels busier and slightly louder than when I use the internal DAC.
Differences between DACs are extremely minor unless something is wrong with one.The Nova internal DAC sounds much better to me. I have spent about two weeks switching between the two trying to establish exactly what is different about the sound. I can't describe it (I don't have audiophile vocab) but ultimately I unplugged and packed the SMSL DAC for good. You can see from Amir's table where the SMSL sits despite its age. For whatever reason its sound through the Nova feels busier and slightly louder than when I use the internal DAC.
FYI, it takes more that a spl meter to ensure levels are matched to inaudible levels.Then I would plan everything, use SPL meters to ensure volumes are exactly matched from one source to another
All the more reason mere mortal like us who don't know how to do all that simply use our ears.FYI, it takes more that a spl meter to ensure levels are matched to inaudible levels.
Minimally best done with a multimeter on a amps output.
And come to wrong conclusions.All the more reason mere mortal like us who don't know how to do all that simply use our ears.
very happyAnd come to wrong conclusions.
As long as your happy.![]()
If the experiment is done improperly, then the results are heavily flawed. Hopefully, you are a member here on ASR and could take benefits from the knowledge of this community.All the more reason mere mortal like us who don't know how to do all that simply use our ears.
Your perfectly welcome to enjoy your preferences but I would just like to add one thing.Hello. I feel kind of silly, but going to share my "new" experience. I use JRiver Media Center, USB out, with the Peachtree ASIO driver, and changed the JRiver Output settings to feed at 2xDSD, instead of PCM. This unit now rivals the sound of my long lost (and dead) Cambridge Audio Azur 751R V2. Tight, controlled, VERY low bass, with solid mids and crips highs. This setup produces stunning clarity, sound, coupled with all the power the Nova300 delivers. I have to turn the volume up hgiher vs PCM, but what a difference. YMMV, but you I suggest giving these settings a try, letting JRiver (or capable front end) upscale to 2xDSD, and see what you think.
Sal1950, thank you for the reply. After further A vs B (no upsampling, leveled), and "I feel silly" all over again. I think I allowed my mind to play tricks on my ears (perception). It's fun to tinker, and I'll continue here and there, but you are right. I love this amp, upsampled signals or not. Thanks again.Your perfectly welcome to enjoy your preferences but I would just like to add one thing.
IF the upsampled files do actually sound different, and it's not just some sighted bias disturbing or influencing your perception, the only other answer is that the sound of the original mix has been altered in some way and your no longer hearing what was written to the digital source. Upsampling like this can never add musical information to the stream that was not in the original file. To hear that your best playing back the file in the manner it was recorded.
But first you should go back to the beginning, listen to the unaltered original file and your upsampled file using some science in the methodology.
(Levels matched withing 0.5 db or better and listened to under double blind bias controlled conditions)
You just might change your mind on your findings.
Cheers
No problem, happens to us all.Sal1950, thank you for the reply. After further A vs B (no upsampling, leveled), and "I feel silly" all over again. I think I allowed my mind to play tricks on my ears (perception). It's fun to tinker, and I'll continue here and there, but you are right. I love this amp, upsampled signals or not. Thanks again.
Sal, I appreciate your replies and wanted to say there is indeed a difference. My wife, a non-audiophile wanna be like me, confirmed it sounded different, and that my mind wasn't playing tricks on me. Upsampling to 2xDSD sounds better to me, less pronounced high-mid range (shrillness?), while not taking away the overall dynamic range, with a more pleasant sound vs straight PCM. Perhaps there is some sort of DSP entering the chain. I then found this interesting blog, describing what I am perceiving - https://archimago.blogspot.com/2013/09/measurements-pcm-to-dsd-upsampling.html. An older post, an older version of JRiver MC, but may explain whatever might be going on, but I am not technically literate enough to fully grasp it, but do get the concept. FWIW. Thanks again, and all the best.No problem, happens to us all.
The mind is a very funny thing, it likes to see and hear what it wants to unless we hold the reins on it very tightly..
Enjoy your testing and tweaking, we all learn thru those same steps.
Cheers,
Sal
