Even Freddie?Anybody who vacuums the carpet, while listening to music, should be burned at the stake!![]()
You got me there!Even Freddie?
And they probably bang on endlessly about "loudness wars" or the price of fish....Anybody who vacuums the carpet, while listening to music, should be burned at the stake!![]()
Oh no. More home movies from voodooless !You got me there!
Do modern DACs treat the two formats equally.
- Modern DACs do not process PCM and DSD with equal accuracy in practice. Most popular delta-sigma DAC chips (ESS Sabre, etc.) run an internal multibit PCM-like path; DSD is converted/expanded internally and generally measures a few dB worse than the chip's best PCM SINAD on the same hardware.
This conclusion is suspect. The AI has integrated audiophoolery into its analysis.
- DSD can sound different from PCM of the same recording due to several measurable DAC-level mechanisms: differing reconstruction/low-pass filter characteristics (typically gentler in DSD mode), the character of ultrasonic DSD noise interacting with amplifiers and speakers, and the choice of delta-sigma modulator oversampling rate. These are real, measurable, hardware-level differences — not mystical properties of the 1-bit format.
Good catch. It would be more accurate for the original post to say that “Many modern DACs using the ESS chips have a greater SINAD for PCM than DSD especially if the bandwidth for noise measurement is 90Kkhz.” This is because the DSD slow roll off output filter allows ultrasonic noise to bleed through and be measured with the analog audio signal.The generalization is tricky.
With SDM DACs PCM (input) ALWAYS gets upsampled and goes through the SDModulator before the final reconstruction filter for conversion to analog.
Unlike DSD (input) in conjunction with DACs that provide a direct DSD path (TI, ROHM, AKM, depending on implementation) - here the source is passed through untouched and only the final reconstruction filter is applied before conversion to analog. So for these DACs you would get different results.
See for instance here for the audio path of the ROHM DAC: https://www.audiosciencereview.com/forum/index.php?threads/smsl-d200-dac-review.65764/post-2520980
That’s easy—the entire paragraph that I quoted promulgates myths believed by audiophools. For example, the statement “DSD can sound different than PCM” is an impossibility. Or the myth that “ultrasonic DSD noise interacting with amplifiers and speakers” is audible. Or that different reconstruction/low-pass filters produce audible results, unless they are very poorly implemented. Everything in the paragraph I quoted is audiophoolery, not backed up by even a rudimentary understanding of human hearing.Please be specific about what you think is audiophoolery in this thread.
I don't think DSD will ever reach the kind of marketshare betamax achieved before its demise.Perhaps it's a betamax v. VHS moment, and DSD will go the way of betamax for similar reasons.
he's already dead, sorry to be the bearer of bad newsEven Freddie?
The phrase “DSD can sound different from PCM” should be more precisely stated “To some listeners playback of a recording that was delivered in a PCM file can sound different than the same recording delivered in a DSD file”. Intermodulation and harmonic distortion of ultrasonic frequencies passed through the gentler DSD reconstruction filters to amplifiers and speakers can fold back into the audible frequencies. Whether its audible or not will depend on the listeners hearing and the magnitude and frequency of that distortion.That’s easy—the entire paragraph that I quoted promulgates myths believed by audiophools. For example, the statement “DSD can sound different than PCM” is an impossibility. Or the myth that “ultrasonic DSD noise interacting with amplifiers and speakers” is audible. Or that different reconstruction/low-pass filters produce audible results, unless they are very poorly implemented. Everything in the paragraph I quoted is audiophoolery, not backed up by even a rudimentary understanding of human hearing.
But that’s what you get when you rely on an AI/LLM to make rash generalizations and conclusions. It spits out whatever audiophile nonsense it has been trained on—and there is a lot of it on the web. Garbage in, garbage out.
Can you offer some proof that a difference can’t be heard?
Between pretty much any two things, even which way round the fuse is in the holder. It's all nonsense - unless they are also showing you their blind test results (ABX double blind at least 19/20).Anecdotally some listeners claim to hear a difference
Russell's teapot, for the uninitiated.
A question for the ages. Thank you.What has dsd got to do with anything?
