I'm no Dirac wizard either but I've seen worse results. Obviously the delays are way off and I'm not sure what step of your process is causing the issue. Did you try with fewer sweeps before going to the design stage to see if the delays are consistent between session? DiracBC typically will screw up step response with big waves exceeding the initial impulse but usually not this bad. Asking some questions on one of the threads dedicated to Dirac will probably be more helpful at this point since you've got the hardware and routing figured out now.
Have you tried the ART trial? I personally had issues with BC but ART is actually worth trying out even for a 2.2 system.
Below is a target curve of Harmon +6 for reference. Not sure what your "before" looks like or what exactly your measurements are supposed to represent with current labeling. Look through Keith's guide to help figure things out.
