DaveBoswell
Very interesting analysis - thanks for sharing. I have been meaning to try something similar in my system for some time so this is helpful.Attached you may find a recorded kick drum transient (duration roughly 200 ms).
This is a REW scope capture at MLP (3,5 meter distance) of my system reproducing this signal:
For the sake of simplification, this is the impulse of the signal downmixed to mono:
And this is system's impulse response from the scope data:
Overlay of the impulse responses:
Phase around 44Hz fundamental:
Overlay of ETC plots:
Wavelet 1/1 of the signal:
Wavelet 1/1 of the system response:
This is a rather crude method, measured at a single point. However it can give you a rough idea on the potential signal demand and some idea about in room reproduction of it.
Did you by chance think of measuring the time domain response at the MLP of the drum beat signal before and after the application of PEQ? This would give some more credence potentially to the premise in this thread from the Video that PEQ reduces tactile impact. I would have thought that they would not be as dramatically different as your "Overlay of the Impulse Responses" plot.
Also - IMO I think the overlays of Impulse and ETC might be a little misleading as the vertical scale may not be directly comparable between the two: if both impulse responses result in the same SPL response in the frequency domain, then the sum of the area under the ETC curve over the time window must be equal - the only way this could be true is if the initial rise of the Signal is much higher than that of the in-room MLP measured result.
Is there a way to corelate the REW Scope vertical axis measurements to actual SPL?
You get the picture
