Paul Hales on room equalization on Soundstage! Network
I use essentially the same process. Subs are tuned outdoors on the driveway, typically to crossover at 100Hz, +/- 20Hz.
Room is fairly large, so modal correction turns into sub correction.
If i'm not lazy, and have the ability to place anywhere, I first use the reciprocity technique to determine good sub placements.
By putting previously tuned sub (aka flat magnitude response) at listening position, and moving mic around the room looking for spots of smoothest response to place sub(s). Helps to have real-time dual channel measurement system visible as mic is moved around.
But more often, being lazy and wanting to try either mono, stereo, or LCR of some new DIY effort, I just stick the sub(s) where I want.
Then play pink through the subs one at a time, and smooth the response. I put all the indoor EQs on a separate layer that can be turned off, or easily altered. (Outdoor tuning has a permanent EQ layer not to be touched.)
There's no target curve I work to indoors, just the same flat response I had outdoors.
Reason being, I keep a real-time volume control on subs, along with master volume. For me, one of the most useful tools to enhance playback enjoyment that I know of.
I don't try to kill peaks very precisely...happy to leave mounds with chopped off tops. And I don't try to fill in dips, unless they are broad and respond to EQ very well.
Heck, I often don't do anything, because I know I'll be dragging the gear outside on the deck to listen to the glory of no-room-modes !!! with greatly reduced boundary reflections (main speaker) !!! Then come back inside and cry, no matter how well the room is "corrected" lol
A lot is untold here.
Let's say you have a 6m listening room. The speakers are right up against the front wall, and
and instead of a back wall, the room extends infinitely.. ;)
While EQ works, it's a compromise compared to dealing with the root. With EQ you win some and loose some.
But EQing a major audible low frequency resonance is clearly better than nothing.
What if I asked you to rank equalizing peaks versus Dirac or ARC?
Whether it's FIR or IIR it's a type of EQ. But Dirac Art is clearly something entirely different than simply EQ. It uses multiple sources to either fill in frequency gaps or, where appropriate, exploit phase relationships and cancellation between sources. The resulting time-domain behaviour can also be very good, which is something you don't necessarily get from conventional EQ.
I also think it matters what kind of room resonance we're dealing with. A deep, narrow resonance at a higher bass frequency can be particularly problematic to treat with EQ because the required filter can become very deep and narrow, while the resonance itself may have significant energy storage and ringing.
Pat Brown of SynAudCon described exactly this when he encountered a 140 Hz resonance in a room:
The “surprise” in this space is a series of LF resonances that rendered the room useless for voice-over recording at the workstation. The room effectively “rings like a bell” at 140 Hz. This became shockingly apparent upon the first attempt at recording at the workstation. It was laughably unusable. Equalization is an obvious first-try solution, but the required deep filter created a subjective impression of “something missing that should be there, and something there that shouldn’t be.” It just sounded bad.
He further went out to treat the resonance with two Modex Plates, with a very good result.
That doesn't mean EQ is inherently problematic for resonances. If the same resonance occurred much lower down, say at 40–50 Hz, the subjective result of reducing it with EQ could be quite different. At those frequencies, the resonance is dominated by room modes with much longer wavelengths, and there are also practical differences in how much bandwidth and acoustic energy are involved.
How would compare "impact / slam" outside compared to inside? While I understand why inside can mess things up, when I have been in a small room with an actual kick drum I certainly felt the impact.
Sorry for slow reply...traveling. in a nutshell, my experience is ouside always sounds tighter, and the hit cleaner than inside. Difficult to assess strength of hit vs inside due to need of having to turn up sub to accomodate reduced boundary loading.
Inside, hit/slam can be just as strong as outside, just not quite as clean sounding/feeling. Blowing empty beer cans around is proof of that lol.
Mono does the best job of matching outside, and will blow beer cans at less SPL than stereo. I,m convinced sub transient are a vector summation, and is why multiple subs come with the cost of gaining smooth response, vs the expense of reduced hit/slam. Just my experiences
If you have something specific, i will try to reply
No thank you, it is your knowhow.
I think everybody has its own way and approach leading to knowhow.
I once met a guy in restaurant at sea, and he asked me to solve "emphasized subbas" from his Dynaudio based standmount stereo system, ( it has nothing to do with brand mentioned ).
So I started:
- use plug to tune bassreflex port ( a: no I do not want ).
- use high pass in signal path ( a: no I do not want ).
- treat your room with bass trap panels ( a: no I do not want ).
- use DSP ( a: expensive and not analogue ).
- use musical subwoofer ( a: I have lot of subbass already ).
- sell it and buy only 5" speakers ( a: no I like these 7", I do not want to change it ).
- also I told him to move the speakers...
I was polite enough to tell him what I really think about his "religion", but I told him that a tad from everything will make a good complex of things to solve the problem with emphasized subbas range.
Probably each one from the list will solve it too.
