The topic at hand at the moment is pretty narrow, will we lose impact if we EQ at 60-70hz, beyond the excessive impact introduced by a room mode. Let us stay there? I vote no, and I have explained why. I have seen no evidence to the contrary.
I am surprised how long this discussion is going on.
Part of the problem might be that frequently terms are used that do not have a clear meaning.
What is “impact“?
Those arguing with the change of “direct sound“ seem to understand this as the early part of a kick drum signal (≈25ms?).
But when you speak of “excessive impact introduced by a room mode“ this seems to mean the total of the drum stroke, including the room response.
The former group might speak of “loudness“, “volume“ or “energy“ instead. Or something else, idk.
How about looking at the physics first.
I use the kick drum stroke from earlier in the thread as example as kick drum seems to be what this is mainly about.
Let us imagine we had a perfect speaker (ruler flat in magnitude and phase) and a room with a room mode peak at 60Hz.
Now we look at the original signal (
black) and a filtered version (60Hz, Q=6, gain=-7dB |
orange).
The filtering obviously reduces the early energy (from 10ms on) in the output somewhat.
The filtering effect becomes even clearer when looking at ETC (right).
We can look more closely at this effect by performing a Fourier Transform to show the FR for the first 30ms. It shows a reduced level in energy below 80Hz.
For comparison the other graph shows the FR for the full impulse.
This is the sound the perfect speaker will emit as sound pressure.
Now, let’s look at the room sound.
Let us assume the room has an initial time gap after the arrival of the direct sound during which there are no
meaningful reflections at the listening position.
As the room cannot change the sound during this time gap, the graphs above show also the sound arriving at the listening position during this time.
If the time gap is longer than 10 ms (in this case of signal and PEQ) then the “direct sound“ is altered and reduced in energy by the PEQ (as expected). If this corresponds to the meaning of “direct sound“ (in bass) is another question.
I.e. have a look at the time ≥40ms: There the energy with the filter is greater than without! However, this does not fully compensate for the early reduction, as the energy is quadratic in amplitude (shown).
After the initial gap the reflections in the room will add to the signal according to size, treatment and so on. The result will be complicated, but we do know that there is a room mode with a peak at 60Hz, as we decided to implement a corresponding PEQ.
So the original impulse will create an overemphasis around 60Hz in the (total) energy of the kick.
The filtered version will create a (more) balanced total energy.
TL,DR:
With the PEQ, there is a reduction in the early energy (mainly 10-20ms) in the frequency range of the PEQ that will be compensated for in the total energy by the room response.
Without PEQ there is an overemphasis in the total energy from the room mode.
Now the question is, how does this play out for perception.
I want to leave this to experts that do know much more than I do in psychoacoustics.
Only one thing:
If I understand Toole correctly, then in (low) bass we do hear predominantly the steady state magnitude of sounds and not the details of the time domain.
So what does “direct sound“ sound mean for sound in bass of ≈60Hz?
Can we perceive the time shift of bass energy from “early“ to 30-100ms later when the room delivers the energy to arrive at a satisfactory total?
[my guess: NO, or only in extreme cases]
OTOH we can definitely hear the overemphasis from the room mode without PEQ.
