but I do know amps can clip either due to a lack of current capacity, or from a rail voltage limitation![]()
Yea, the extraction process probably went like "This is wave A, extract 50Hz from it". Then of course the extracted wave would be a clean 50Hz.I wonder what it is "extracting"? Evidently extracted 1kHz still contain 50Hz component. Probably clipped![]()
Notice your clipping is not at a fixed value which is what is expected or rather defined as clipping.
Meaning the mathematical function of the clipping is not "if value above >1, set to 1", but rather something else.
How are you generating the combined wave? For all we know the equipment could be doing "If ( channel 1 + channel 2 ) > 1, clip channel 2"
The 'extraction' worked like this: the 50Hz &1000Hz summation that is clipped, was sent via XLR to mixer. So was the 50Hz unclipped signal.I wonder what it is "extracting"? Evidently extracted 1kHz still contain 50Hz component. Probably clipped![]()
Even preamps have rail limits, I think the Core110f that is generating the clipped summation, is metering at the output+27dbu.But of course, this shouldn't be the case for a strong amp or preamp driving no load, there should be way too much spare capacity for this to happen.
I've been trying to catch the onset of clipping, hence -6dB. I'll trying moving deeper into clipping.EDIT2: Also why would the "clipping sum" be clipping anyway when both your sines are -6dB (usually referring to peak) so when added together they should be 0dB peak which is not clipping. This is giving more suspicion that the sum-er is starting to clip stuff near but not yet reached 0dB.
You're calling this the "clipped 1000Hz" signal, right?
But notice the shape of the clipping is clearly following a 50Hz shape. This is where the 50Hz is missing from.
In the external mixer, the 50Hz was inverted and summed with the clipped summation.....netting the clipped 1000Hz.
50Hz appears unchanged because
How about performing the opposite experiment? Send the 50+1000 summation. And a 1000Hz unclipped signal.
In the external mixer, the 1000Hz is inverted and summed with the clipped summation. You will get what you would call the clipped 50Hz. Which would be a 50Hz wave with 1000Hz components carved out of it. Just like the current "1000Hz clipped signal" has 50Hz carved out of it.
So you sum them still in the digital domain? Then of course you'll get digital clipping. Even if the mixer works in floats, the DAC will only accept integers, so you'll get clipping during float->integer conversion.The combined wave is per #18....two sine generators being summed ala mixer, and sent to processors DAC.
The mistake you are making is with your waveform visualisations with a low frequency and the high frequency "on top" while showing the LF as a "separate" entity.Yes, it is the sum of the sine waves that clips. That is what i meant to be saying. Superposition of frequencies has the higher frequency sine riding on the lower.
Seems to me that always puts higher frequency content at the peak voltage .of any sine summations.
Here's a 50Hz and 1000Hz scope shot of what I'm trying to convey.
Blue trace is 50Hz alone
Yellow is 1000Hz alone
Green is their summation.
Summation is of course a higher voltage than either single sine on it's own, but note how the 1000Hz sine rides on top the 50Hz sine. And that superposition is what increases the summed voltage....and the increase in voltage is all 1000Hz sine content.
This example starts with equal voltage sines. Clearly if gain is raised to both, the 1000Hz sine will be the first to hit an amps rail voltage limit.
So let me move on to unequal voltage sines..
Here I've 4X the voltage of the 50Hz sine, leaving the 1000Hz unchanged. Equivalent to +12dB SPL @ 50Hz...hey my sub needed some boost, lol !
1000Hz still rides superimposed, and will be the first to hit the rails, and clip.
To the extent music waveforms are a collection of sine waves ala Fourier, seems to me higher frequency content clips first, as amp gain is raised.
Only works if the crossover (frequency separation) is done upstream of the amplifier. IE Active crossovers.It is one advantage of a bi-amplification.
Clipping is a nonlinear phenomenon, e.g. 2clip(x) ≠ clip(2x). Superposition does not apply....
However, no matter the ratio of amplitudes, higher frequencies are superimposed on lower frequencies, and will be the first to clip within the range of the onset of clipping into full clipping saturation of all waves. Music, multitone, two sines, whatever....
if they have equal amplitude, the 1000Hz will ride on top of the 50Hz,
doesn't allow FFT to paint the full picture, apparently because it's not a constant state condition.
www.audiosciencereview.com
You may actually also find the teachers don't fully understand what is going on either. As an alternative way of getting your head around it. If you think of the low pass filter to extract the 50Hz, what it will do is essentially draw a line through the mid points of the high freqency modulated waveform. When you cut off the top and bottom peaks of that waveform, the midpoint shifts also.Between you and my measurement class, I'm think I'm finally going to get this fully sorted. The measurement class is international, and language issues can sometimes form misleading conclusions. thx again
