watchnerd
Most recordings are made to be played back on earbuds and car speakers
Indeed.
And little mono smart speakers.
Not as ugly as Genelec.
Aesthetics is purely down to taste, I think the barefoot monitors look like chunky, fisher price rubberized plastic boxes whereas white Genelecs look like high tech art pieces.
Maybe in black it isn't. But the white one is pretty damn sexyWell, I think they're both kinda ugly compared to many passive choices.
Neither one looks living room sexy.
They can.Regarding SPL capabilities, my Genelec 8351B are capable of more power than my ears can tolerate, even on bass-heavy songs, in my relatively small office room. If anyone wants, I can test them in a medium room and measure SPL to see if they can reach a desired SPL with a bass-heavy song.
Can you please do that. My main concern with that speaker would be its max output at say 3-4m or so. Crossed to subs would be an even better test(for my selfish curiosity ), as I'll have subs to take care of the bass, so it should give a truer sense of max output. Good thing with those is you don't have to worry about damaging them.
I honestly have no idea from the measurements why the Genelec 8351B sounds so amazing, while the KEF R3 were comparatively boring.
I am also curious about this. And to understand whether they really need a sub in a medium room. Mine is 14 x 22 x about 9.5 (3,000 sq ft).I’ll give it a try. Might have to wait until tomorrow to avoid disturbing my wife though
How so? I had assumed these active speakers must be using EQ to achieve such flat and extended bass response.Particularly since the Genelec is not using EQ in those graphs.
I was using the Sonos Amp to power the KEF R3’s, which from Amir’s review is capable of delivering 200 watts per channel. It doesn’t seem like that should be an issue, but who knows? Yet another reason I find myself preferring active speakers.Amplification differences?
For the Genelec's, driver amplification is optimised.
For the R3, it depends on amp used?
I thought Amir said he did the testing with nothing engaged. But maybe there is a default amount of EQ being implemented and the user can adjust it to his/her needs?How so? I had assumed these active speakers must be using EQ to achieve such flat and extended bass response.
Being a high-end monitor, there are a lot of features which I will let you read on your own elsewhere. The configuration you see is how I tested it. I performed a factory reset and left all the switches to off.
My room is on the 2nd floor, so definitely not concrete (thought that might have been a good idea). My ceiling is actually vaulted and ranges from 8' to 11'. But anything you do is fine and appreciated. I am not a headbanger, and most of my music is not bass heavy.
You are right, of course. I forgot about the DSP based cross-overs. When you think about what you get "out of the box" with the Genelec in terms of performance it is pretty incredible.An active speaker with active DSP crossovers doesn’t really have any such thing as “no EQ”, depending on what you mean by “EQ”. Even when it’s performing in its default flat mode with no room correction, an active crossover means that each driver is being powered by a signal derived from DSP. Whether you call that EQ or not depends on what you mean exactly by “EQ”.
