FWIW, I was surprised how good the 8351s were in a mid-field (350-400 cm from speakers) set-up at my importer’s place. The 8341 and 8331 were not as convincing from same distance.
(Just one experience in one situation!)
Genelec coaxs are too rich for my blood (I think very reasonable pricing for the amount of genuine innovation on offer though). The huge waveguide affords exceptional directivity control for its size, which is probably why it gave that effect in midfield, barring SPL limitations. Though I do wonder why the need for slotloading, and not using side-mounted woofers and leaving the waveguide baffle continuous with the rest of the enclosure. Someone once claimed to me on DIYAudio that the slot-loading lowered the directivity control frequency compared to using direct radiating woofers (basically in a way similar to the DD 8Cs passive cardiod), though I can't figure out why for the life of me. Not even
Genelec's own excellent white paper mentions the role of the woofers in directivity control - they only mention the huge waveguide. FWIW there is some
compression and intermodulation in the lower midrange that appears to be the result of the slot-loading, lowering measured max SPL to a surprisingly low level given the amount of woofer surface area. The max SPL in the bass is also low as well. The paradox of this speaker is in how exceptional directivity control has the greatest effect at relatively large listening distances where the direct sound doesn't dominate as much, but the max SPL might not be high enough for listening at that distance.
FWIW, I'm looking at active coaxials for my next setup, but budget options are thin. It is frustrating that the best direct-radiating coax drivers outside of the Genelec are all passive - TAD, KEF (except LS50W which doesn't suit my needs), ELAC and Technics. There's
this sealed box coaxial that I'm slightly curious about, because of how they've managed to cram in FIR DSP, active crossovers, manufacturing in Germany and using a custom SEAS Prestige coax for LS50 passive money (also I want to try something without a port for a change). But their own curve:
looks nothing like what an independent lab measured unsmoothed in the review, even discounting the scale differences:
I don't think the factory graph looks excessively-smoothed either. So I shot them an e-mail with both graphs traced in VituixCAD, overlaid and smoothed 1/12-octave hoping to clarify. If it turns out there was a revision after the review that reduced some of the waviness in the FR and it is indeed +/- 1dB except in the bass (easy to EQ for anyway) as their own graph suggests, I might jump on it as the polars look nice enough.
