75 hertz is a resonance. It's out of phase with the dominant resonance.
Top graph. I'm pretty sure you can read a graph. On a dB scale it is a little bit different to read. Top graph is measurement of the signal sent to the driver via an amplifier and picked up with a microphone. A SPL based frequency response. Red and blue is where this driver is singing along with the signal. The driver is adding in different parts. A second harmonic is one octave above and the third harmonic is 2 octaves above the fundamental frequencies. A difference between the measured signal black line and any other line 40dB lower is expressed as 1% Harmonic Distortion.
Calculate THD and distortions decibels dB to percentage % per cent percent voltage % vs converter and dB signal distortion THD+N total harmonic distortions factor attenuation damping - Eberhard Sengpiel sengpielaudio
sengpielaudio.com
If you really want to do some sleuthing you want electrical phase, SPL and Impedance on the same graph. They can tell you a fair bit about what is going on.
Now that you have your leaks plugged you can do some better measurements.
Until you actually have your drivers measured our simulations are best guesses. But they do point you in the right direction.
If you had your drivers measured, the simulations could be very accurate.
Should the build your own loudspeaker become a hobby you should always start with a driver that has been exercised for about an hour at a few watts of input power via noise signal. And then take some measurements for the basic driver parameters. Let your driver cool for a few hours and then measure again. That is the best way to measure power versus small signal. The idea that high power Thiele Small calculations can be made means that you need alternate mathematics to do the large signal calculations. Taking small signal (millivolt level as they should be) on a warmed up driver is the most accurate way to get the different functional and cold difference. There will be differences between a warmed up driver and a cold driver. As a mechanical system your woofer is less than 0.25% efficient. That is right. 99.75% of the power going into your woofer is being turned into heat. Thankfully the power input is low, and the duty cycle is fairly low.
Mark
