mwmkravchenko
So in order to see what happens a way down low for some enclosures Hornresp can simulate down to 1 hertz.
This is your box as you have it mass loaded for your measurements.
@mwmkravchenko in your vituix sim where did these numbers come from for the APR10? They are substantially different from the stated specs for Vas, Fs and Qms.
The box is tuned via your PR's. The woofer will not change the properties of this system. Your resonance is most likely a woofer resonance as it keeps pretty consistent.The woofer itself won’t change the resonant properties of the box though right? That’s the box volume + PR tuning and that’s what’s causing our mismatch here, I could put another driver entirely in there and aside from differences in displaced volume in the box, the resonant system of the enclosure would be unchanged.
The resonant peak of the woofer in all of the various sims/measurements has been reasonably consistently in the high 30s/low 40s Hz.
You aren't getting useful output below 40 hertz. So losing the weights gets you efficiency.What’s the advantage to ditching the weights and tuning the box with EQ?
Mark
The ripples in your impedance test showed leaks. At least the possibility of leaks. As for lacking deep bass, well that's a part of the system design. System starting with the driver. It has strong output to 40 hertz. But not a lot below. You can' raise that output via PR.@mwmkravchenko may have found part of the reason I didn’t have spl down low. Drivers were leaking enough that at low hz and high spl it was making audible noises. I’ve sorted one out.
Very much better!
