EngineerNate
- Joined
- Oct 6, 2018
- Messages
- 328
- Likes
- 369
- Thread Starter
- #61
They make a larger square Neutrik jack.
lol noted for if I ever pay attention to this after I get these running.
If you seal the box first, you can mask and paint the area black around the PR's it will not look that bad.Got the speakOn connector mounting done.
Moved on to fitting the drivers prior to final finish work.
Ran into a snag. These two things are not the same!
Fortunately a difference I could accommodate with some hacking. It’s not pretty and it’s a little upsetting after spending this much time on the cabs, but these things happen. Cutting a perfectly straight cut through a driver hole wasn’t gonna happen. I may do some additional clean up with the kutzall. I may not.
I did clean up the second one a bit after taking that pic.
Drivers fit nice now.
Also found out my assumption the CSS PRs were the same diameter as the drivers was incorrect. Eventually I’ll need to 3D print some filler strips. The website didn’t list a diameter. I should have asked.
All things I can address in the 3D model for if I want to build another set or if anyone else would like to build a copy.
Cheers,
Nathan
PS-I always joke that it’s not a real project until you bleed on it. Well. I was cleaning up the inside edge of the driver cutout with some sandpaper and caught a splinter and got it a solid 3/8” up under my nail. That did the trick! Fortunately came out cleanly.
Are you asking me whether you think the box should be upside down (woofers closer to the floor)? Without reading the whole thread, I don't know what the bandpass is. But I would have thought that the wavelengths are so long that it does not matter, all it's going to do is shift the reinforcement by maybe 5-10Hz up or down. One of these orientations is going to be better for you. Or ask someone who actually knows ... like @sigbergaudio or @Duke.
@EngineerNate Can you summarize the question / alternatives you are pondering so I don't have to read the entire thread?![]()
