Hello everyone,
I'm currently doing acoustic measurements for my engineering thesis in an anechoic chamber using a Brüel & Kjær Pulse system, and I've run into some strange low-frequency behavior that has me stuck.
The design is a compact active 2-way monitor with a Dayton DSA135-8 (5") woofer coupled to a passive radiator (PR). I'm taking near-field measurements (mic < 1 cm from the dust cap) using a Log Sine Sweep to avoid the 50 Hz mains hum of the lab.
The issue: I cannot observe the classic attenuation dip (notch) in the woofer's response at the tuning frequency (fb).
Theoretically, at fb, the woofer's excursion should be minimal as the PR takes over the acoustic load (just like in a bass-reflex ported system). However, my woofer's LF response is almost flat and rolls off smoothly without any pronounced dip.
I've attached two images for comparison:
this is from a practice project we did in class with a bass-reflex system, meassuring nearfield responses near the woofer and the vent.
this is the response I get near the woofer, where there's no attenuation.
Checks I've already done:
Any insights or measurement suggestions would be greatly appreciated.
- I've thoroughly checked for air leaks and sealed everything (connectors, rear panel, etc.) to ensure a proper acoustic suspension.
- Hypothesis: The rear center mass of my PR is a fixed metallic piece (looks like a structural rivet/post). Since the enclosure is very compact, the woofer's magnet is physically very close to the back of the PR. Could magnetic attraction be stiffening or "locking" the PR's suspension, preventing it from resonating properly?
