I am trying to find a smallish set of passive speakers for desk use.
The ones I have kind of considered so far:
Any thoughts?
(Edit: Dimension preference added)
- Preferably footprint under 7W"x8D" - don't care much about the height.
- Unless - I can put the speakers sideways under the monitors - I have 6-7" clearance under the monitors.
- Modi3+ DAC -> Magni Heresy -> HD 6xx for headphones. I have the Sajab A10a for speakers - also fed from Modi3+.
- Currently using Micca covo-s that I have had for a couple of years. Pretty mediocre speakers - no instrument separation, harsher treble, no bass.
- I tried using my Wharfedale diamond 10.1 on the desk but they're _huge_. Love the audio on these - currently serving as surrounds in my HT setup.
- Desk would be 72"x30" with 2 27" monitors so distance from me would be 2 maybe 3 feet. No place behind the desk.
- Desk has computer CPU tower so putting speakers on the side of the desk may not work.
- Budget less than 300 USD if possible.
- Micca mb42x/rb42 -- not sure how much improvement over Covo-S
- Jamo S803 -- so far like these the most. They're not small but better than the Wharfedale.
Any thoughts?
