- Joined
- Jul 21, 2018
- Messages
- 837
- Likes
- 638
I am using a pair of pro-audio Tannoy V12s designed for sound reinforcement which are intended for use with subs, which is currently what I am doing (3 x active). I am curious as to whether the crossovers within the Tannoys which presumably cut the frequencies below 70 Hz, merely dissipate the energy from the amplifier as heat, or whether something else is going on?
Apologies for the rather naive question. I am a bit of an electronics ignoramus!
Thanks in advance.
From the Tannoy manual...
Frequency response (1) +/- 3dB: 70Hz - 25kHz
(Have attached the manual from the earlier models... Essentially the same.)
Thanks in advance.
