Parts Express Dummy Load Performance Measurements
MAB
Portland, OR, USA
I have some Parts Express Dummy Loads for testing amplifiers. They have low inductance, high-power rating, are cheap, and get good reviews.
Unfortunately I was surprised to see they distort badly at high power, both the 8 Ohm and 4 Ohm versions. Here are some measurements and discussion.
I don't do much high power amplifier testing, but when I recently tested a vintage Yamaha CR-1020 receiver, I noticed the THD tracked a few other amps identically using the Parts Express Dummy Loads. I wired a different load together for comparison using some spare Parts Express wirewound low-inductance resistors, marketed as 'crossover' resistors. The wirewound load I put together is limited to below ~150 Watts, and gets hot even with a short 100 Watt sweep, so are only good for momentary use at high power. :cool:
Despite that large thermal issue, the comparison of the old Yamaha's measured THD indicates the Parts Express Dummy Load is distorting dramatically, and the quick and dirty load I made of the Parts Express wirewound crossover resistors is working great:
Wow, the Parts Express Dummy Load has significant distortion above just 1 Watt. I tried a few more cobbled-together loads from some additional chassis-mount Dale resistors and got the same good performance as I got from the PE wirewound resistors.
Regarding the source of the distortion in the PE Dummy Load: If this is solely caused by Voltage Coefficient of Resistance (VCR), or Temperature Coefficient of Resistance (TCR), these would be easily measurable at high power due to the large amount of distortion. I have an LCR meter with a DC bias adapter and a high power DC supply. I measured the Parts Express Dummy Load from 0 V all the way up to 28V bias, the VCR is smaller than I can measure even with a fairly competent Hewlett Packard LCR. I am able to measure R and Z to 100kHz, across DC bias, I see small change due to inductance, but an order of magnitude less than needed to explain the observed rising distortion with power of the PE Dummy Load, >30dB at 100 Watts.
5 Watt Dashboard Comparison:
The poor performance of the Parts Express Dummy Load affects the dashboard measurements, here is the Dale chassis-mount on top vs. the Parts Express Dummy Load on the bottom:
The Parts Express Dummy is has 15dB degraded THD at 5 Watts. Note the odd HD with the PE Dummy Load.
I did a search and see our own @RickS reported the same issue on the QuantAsylum forum some time ago:
I also notice; all of these dummy loads make audible noise when high power is applied.:eek: The Parts Express Dummy Load makes a particularly odd sound compared to the noises emanating from the other resistors. I want to check this out more. With a microphone.
I also don't have a good load resistor that can withstand high power. So I constructed a (hopefully) good load, that can take high power. And I made measurements of the performance, including the sound.:)
I will also avoid doing any more high power testing of the 47 year old Yamaha:D, so instead measurements will be made with a Bryston 3B-ST, which I purchased new in the late '90s.:cool:
High power load resistor:
I built the 8-Ohm load resistor out of eight 1-Ohm Caddock MP930 30 Watt thick film resistors. I have some MP9100 100W parts somewhere but can't find them. In any case, the MP930 give me a maximum power of 240 Watts, so long as they are sufficiently cooled.
If cooling isn't adequate these tend smoke-out rapidly. So I built a water cooler out of HVAC tubing and copper plate:
The copper tubing is brazed onto the backside of the thermal transfer plate. I can use water cooling on the resistors in case of long term power dissipation. It can be used for single measurements with short duration even without water.
I got the surface smooth to mount the TO-220 package resistors:
This contraption connected to my sink with just a trickle though the hose is really overbuilt :p, limited by case to copper conductivity, not by the cooling capacity. So I should get the full rated 240 Watt power handling out of this load if I need to do a long duration measurement.
Comparing THD vs. Power of a few load resistors:
The below graph compares the Bryston's measured THD vs. Power with the Parts Express Dummy, the wirewound made from several Parts Express crossover resistors, and the Caddock Thick Film load.
A few things stand out. The cobbled together wirewound load performs the same as the thick film load, even if it is under-speced for long term power handling. It's thermal change in resistance is small even though it got uncomfortably hot to touch right after this measurement. Larger FFT sizes probably would get the load into trouble. The PE Wirewond and Caddock MP930 are identical for short term measurements. The PE Dummy Load isn't appropriate for distortion measurements above 1 Watt for measurements below 0.1% or so. The Bryston amp is almost 30 years old, never been touched, and still has great performance. Here is it's dashboard with the Caddock MP930:
The fact that the Caddock MP30 don't exceed the performance of the various wirewound I used is somewhat relieving. I wasn't interested in going into the sound of a resistor here. But, let's talk about the sound of resistors anyway in just a bit.;)
Some additional thoughts on Temperature Coefficient of the Resistance:
I did sweeps with the resistors soaked under power and hot. The Dummy load is so thermally massive, yet it behaves the same with a fast sweep from cold as it does when cooking hot. I would think it would measure worse at high temperature. It has the same measured distortion even after soaking at >100 Watts until the case was too hot to touch.
The various wirewound and Caddock thick film resistors also have negligible changes across temperature too, and retain their good performance even when warmed up. I even ran hot tap water though the 'cooler' of the Caddock MP930 resistors to see if anything changed, no measurable change above the level of noise was observed. I think TCR would need to be very large to be the cause of the level of distortion observed in the PE Dummy resistor. Same for VCR, which should be easily measurable with the DC bias and a decent LCR meter. In fact, TCR and VCR don't appear to be an issue in the measurements I made. I am purposely avoiding running the power so high something runs away, which will affect the measurement.:cool:
Measurements of the audible sound from the Parts Express Dummy Load:
I used a microphone placed close to the surface to measure the what I was hearing coming from the PE Dummy Load:
It's not loud, but I can hear it clearly. It sounds bad, like a crappy reproduction of a 1 kHz sine wave. I subtracted out the background noise to get the lower trace. The dummy load acts like a really crappy speaker, ~15dB SPL at 125 Watts maybe slightly higher, frequency response 3.2 kHz to 20 kHz +- 5 dB. ;)
I measured the acoustic distortion of the resistor cum speaker:
Wow, all of the stuff I heard with a 1 kHz sine tone is higher order harmonics. Lots of ringing of these various harmonics. For example, here is the response feeding 1.325 kHz sine tone at high power, ringing the dummy load at 5.3 kHz.
Most of the sound is the higher harmonic ringing. And the FR of the block of metal and resistor and encapsulation is preventing me from making any meaningful discoveries.
I wonder if the potting of the resistive materials is vibrating. It's not clear what the vibrations are doing. They may be modulating the geometry of the conducting films, altering the impedance with voltage and frequency. There may other sources of distortion, depending on the material of the conductor and insulator, and if the vibration creates friction or pressure. Or all of the above, and some things I can't think of. In any case the resulting distortion above 1 Watt makes these not useful for distortion measurments. All four of PE Dummy Load resistors I have show the same behavior, both 8- and 4-Ohm. Unfortunately, this makes them useful only as a soak resistor, not useful for performance measurements.
Thanks for the detailed analysis. I ran into this years ago when I attempted to measure the Benchmark AHB2 and could not replicate their results. The AHB2 made for a wonderful test bench to find lowest distortion load resistors and what I use now, reflects that. Different amps are more or less sensitive to this.
On VCR, it is a very complex phenomena which is not well understood. As you found out, temperature coefficient does not directly correlate with it. The issue only shows up at higher powers. Up to about 5 to 10 watts, it is not significant but then starts to shoot up with the parts express like resistors.
I use very high power, non-inductive resistors which I think are rated at 250 watts but can tolerate something like 10X more for very brief periods. I use 8 ohm ones and for 4 ohm, two are paralleled. That helps spread the load. I put them in an all metal, server rack case which helps a lot with keeping them cool.
As it seems to correlate with the acoustic sound the resistors make. It could be something mechanical/vibrations? Or non-linear magnetic effects?
Caddock MP9xx are my favorite resistors by far, I have wrote about them many times.
Never-ever failed me.
But it's the first time I see them in such an application, very interesting!
Reactions: MAB
We already have this nice thread "ASR dummy load configuration" where @Langston Holland's post #97 and post #98 are really thorough in-depth and worthwhile.
Even though I am not an expert in this kind of precision measurements, I use ARCOL 8Ω 100W resistors for silent "burn-in" (we call "aging" in Japan) of my amplifiers (ref. here) as well as for silent Fq-SPL measurements of amplifiers' SP high level outputs (ref. here).
I also use the similar 22 Ohm(Ω) 30 W non-inductive non-polar wire-wound power-type metal-clad resistor (FHN50-22OHMF, PCN Corporation, made in Japan) for fine tuning of midranges, tweeters and super-tweeters (ref. my post #976 on my project thread).
Yeah. I think the acoustic phenomena in the Parts Express Dummy Load is different than the usual VCR. For instance, it doesn't show up in the DC measurements with the LCR meter, even at 28V DC bias! If it is mechanical vibrations, that would explain why DC shows nothing at high V, but AC shows significant issues at the same voltages.
Some background on the effect, it seems the trimming process has influence.
https://www.mouser.com/pdfDocs/20240606vcr.pdf
I have to wonder if this Dummy load, which I suspect is essentially a heater wire embedded in some encapsulation is just vibrating back and forth in the encapsulation, slamming against the the boundaries, which would be 2x the fundamental, and we do see lots of 2nd order HD in the acoustic measurements.
Here is my diagram of the resistive wires slamming back and forth in the encapsulation.
In reality, there are wires wound bifilar in both directions, making the resonances even more complicated. And I am not sure if impact is right way to think about this, the primary issue may be friction within the encapsulation.
Just my thoughts, based on these few observations. But not able to make a firm conclusion. But that PE Dummy does distort like crazy.
It has been a while but I don't recall mine making any mechanical noises.
Those ARCOL chassis mount seem to be a gold standard. I have a 4 Ohm load made from them, but it will only take about 100 Watts so I couldn't do a fair high-power comparison to the 8 Ohm Parts Express Dummy resistor. Suffice to say it performed really well, equivalent to the Caddock Thick Film resistor. The disadvantage of the Caddock is you do need to provide a very robust thermal sink.
Interesting tests. In the FFT diagram there is shown a lot of mains (60 Hz) peaks and muliple of it. How did this influence the resistor THD measurement results?
The most amazing thing I read on ASR. I am using regular 10 Ohm 10 Watt cement wirewound resistors connected in parallel/series to achieve 4 Ohm 100 Watt resistance. They are sandwiched between two aluminum plates acting as a heat sink. They probably have measurable inductance. But I have never seen anything like what is described in the first post. What is hiding under the heat sink that is so amazing? :) My measurements of the amp are 1 kHz 10 Volts across these resistors, which gives 25 Watts of power. There is no influence of resistors here at all.
Reactions: MAB
There is mains hum in the amplifier measurements, it's ~120dB down on the Bryston amp, 105 dB down with the Yamaha. :D That's pretty small, neither one of these amps has exceptionally large mains for a unit of their era. In fact, the Bryston is just behind a very high performance amplifier like the Neurochrome Modulus series. Would easily land it in the ASR Excellent category.
This mains noise has no impact on the high frequency distortion measurements.
The 60 Hz mains noise is chopped off of the acoustic measurements. My room was moderately quiet, but I still had a desktop computer with fans running in the background. This also had little influence on the actual acoustic measurements of the resistor.
I tried the PE dummy loads a few years ago. Not sure if they changed.
They do seem a good value but despite their claims, the one’s I tested were not low inductance.
Fascinating. Kind of a “Dummy Loads for Dummies”.
Reactions: MAB
Today I finished the assembly of my amplifier dummy load, using an old PC case. The restistors are old stock which I had in long time storage. Think that these are DALE (or equivalent) with 1 Ohm each 1% Tol. and 50 Watt. So I can with patch cables have 2 , 4 , 8 , 12 and 16 Ohm. Mono max. is 800 W when all resistors uses in a certain combination. What the distortion would be, don't know. Since these resistors are all wirewound I fear that I have no power amp with low enough THD for measure it. For continuous testing there are fans which I can switch on.
Hi Rick, do you happen to have the inductance?
The Parts Express Dummy Loads I have are higher inductance than a decent wirewound resistor (like an ARCOL). But not by enough that I can explain this distortion. Here are some of my resistors' parasitic inductances:
Based on the parasitic inductance I measure, I don't see a way for the Parts Express Dummies to induce such a dramatic degradation in the measured distortion. Also, hard to understand why the observed increase in distortion would be sensitive to voltage above a threshold, unless the parasitic inductance is voltage-sensitive. I observe no change in parasitic inductance with the application of DC bias to these resistors while measuring, so this also seems unlikely.
I made a 4 Ohm dummy load with wirewound and a quick and dirty hand wound inductor.
The high inductive test load is about double the inductance of the Parts Express Dummy Load.
Even at 2x the inductance of the Parts Express Dummy Load, the High Inductance Test Load shows no evidence of elevated distortion like the PE Dummy.
Inductance doesn't explain the magnitude of the distortion I measure on the Parts Express Dummies. It also doesn't explain the the sudden turn-on, at least on the resistors I have. They aren't the lowest inductance for sure, but I think this parasitic inductance needs to be on the order of many mH to become significant, even then I can't reconcile the observed distortion. I think it is mechanical, given the surprisingly audible whine they make when measured.
Here is the amp at 100 Watts into the PE Dummy:
The odd order HD is constant to 10kHz :eek: on amp that is pretty clean for odd HD (I just did a complete set of measurements:D). I can't explain this with inductance.
Also, I have an Ohmite/ARCOL Potted resistor, similar looking construction to the PE Dummy Loads. It is for various high power applications, is low-inductance, and is specifically stated to be mechanically rigid.
I measured the inductance, it is low.
Here is the distortion compared to the 8 Ohm PE Dummy:
The ARCOL braking resistor is clean.
Unfortunately, the Parts Express Dummies look like they are poor compared to just about any other high power resistor available, even braking resistors of the same general construction and price. My hypothesis is the PE Dummies are not mechanically well-potted, the resulting audible mechanical noise shows up as a large damped hysteresis in the electrical response of the resistor, which causes odd-order harmonics in the response.
These are my observations on the resistors I have.
Sorry, @MAB but it was too long ago. Since PE advertises them as non-inductive, as soon as I found they were, I complained. As usual, they handled the return well.
Reactions: MAB
Thanks, I almost never save that stuff. And I saw your posts on this were several years old.
Loads dont distort, amps do. Does anyone show the distortion at the input of a speaker and call it speaker distortion? No its the amp. I have never seen resistor distortion measurements dont even know what that would mean.They have non linearities but thats not distortion. I would call this a severely non-linear load that the amps cant handle properly, so its amp distortion.
Actually resistors do. Resistors have noise too. All of this can be measured, and is. :cool:
If you have a time varying signal from a perfect voltage source, and that signal is fed through a resistor with a varying resistance, the output will show distortion unless the time-varying resistance is perfectly in phase with the signal and the magnitude of the variation is linear in the amplifier's output - In this special case only the gain is reduced. As soon as either of these conditions is violated, odd and even order distortion is measured depending on the nature of the non-linearity in the resistor, even if the amp is a perfectly invariant voltage source. Voltage Coefficient of Resistance is primarily responsible for this in most cases, and usually resistors don't have significant VCR until operated above 50 Volts. In most cases, this would be a simple reduction in resistance as voltage is increased, and would show up as second order harmonics, even on a perfect straightwire + gain voltage amp. If the resistor is inside of the amp, I guess semantically you can call it 'amp distortion'. In the case of the PE Dummy load the normal VCR mechanisms normally discussed in literature (activation of resistive paths in the conducting films at high bias) are swamped by a much different mechanism (the resistor dissipates electrical energy acoustically). And the effect is quite massive, which is why I can hear the resistor whining under stress.
Also, I drove a much more reactive load than the Parts Express Dummy, tiny elevation in distortion, perhaps you missed that post. Which also throws cold water on the idea the amp can't handle the reactive load.
edit: typo
