Parks Audio Waxwing measurements
Both will do digital RIAA EQ and gain. Otherwise, the MiniDSP does not have as extensive a feature set as the Waxwing. For example, it doesn’t have the Magic feature (click and pop removal), phase, tone, PEQ, effects options, or as precise control over loading and capacitance, azimuth tools, speed calibration tools, etc. However, the MiniDSP’s measured performance for noise, frequency response, etc., is better. It’s really a question of what you want.
I understand very little about frequency and noise measurements. Does this have a big effect on hearing?
No, the difference between the two won’t be audible. So really, it boils down to features. If you don’t need all the features of the Waxwing—and perhaps don’t want a unit that requires a smartphone app to control it—then maybe the MiniDSP is the better choice given the price. The cutting-edge measured performance is just the icing on the cake.
If you don't want to use a smartphone, the previous Puffin doesn't require one.
Strictly speaking neither does the Waxwing - it just needs something with BLE, and someone to implement the documented API which covers almost everything. Not sure if anyone's actually done it yet. It could run on PC, Mac, Pi, or something like an ESP32 with buttons, knobs, LEDs for clipping etc.
If not Android Phone, an Android Tablet will serve as well.
You don't actually need a smartphone to control it - I barely use the app on a day to day basis.
You need a phone to set it up - assuming the default out of the box config doesn't work for you.
And you need a phone to access some of the interesting "info" features (Like record grading - or input and output levels etc) - or if you are a "tinkerer" and want to constantly play with the settings.
But once it is set up the way that works best for your system - you need never connect a phone to it again if you don't want to.
OK so I have read through all of this. I understand it's limitations. I have been interested in the Parks phono pre for at least 10 years. So
does this thing sound good with carts from 500-1500 USD or not??? Sounds like the limitations are measurable for sure but in the real world not that relevant. Transducers on both front end and end of chain have order of magnitude worse THD specs. And we love the way our systems sound anyway.
Worth Buying??? Sound musical???
I use it to play 78s and scratched mono 45s and it excels there. Personally if you’re just playing good condition lps from 60s onwards then adept is cheaper and probably better bet although waxwing is good there too
The electronics exceeds the performance of vinyl with any cartridge - so yes, it does.
Worth Buying???
Definitely.
Sound musical???
Electronics is not musical - music is musical. The job of the pre is to faithfully reproduce the output from the cart unchanged at the output of the pre - with the exception of 40 to 60dB gain, depending on the cartridge.
This device does this exceptionally well with additional features that can adjust frequency response for flatness - or to taste, and many more (anti rumble, low cut etc)
Plus - use the optical out, and make sure the waxwing has a good ground - and it is close to the best noise killer you can have.
I have used the Waxwing with the following cartridges at gain settings from 38 db to 72 db - all with excellent results.
AT VM95SH - 38db $229
Denon 103 - 60db $249
Hana SL - 60db $750
CA Maestro 2 - 38db $1500
Lyra Parnassus - 72db $3000
The typical issue most “audiophiles” have with the Waxwing is it being a DSP device. The feature set is extensive and made possible by the use of DSP. Once you get past the prejudice of it being a digital device and actually use it - then you will understand what a gift Shannon Parks gave us. It is one of the best values in audio equipment!
I noticed on the Parks website that Shannon is working up rolling out an improved “Magic” firmware update later this year. Given that the guts of the Puffin and Waxwing are so similar, is it reasonable to expect the Puffin will also receive a firmware update? I have not seen any news on it.
he has specifically stated on his facebook page that the puffin will not be upgraded with that functionality. Not unreasonable for him to stop adding features to a discontinued product.
So from what you guys are saying you could use a dig out from the phono pre into your favorite DAC? Adept is the minidsp dig phono pre without some of the features? How well does the pop and click removal software work? Transparent w/o affecting music too much?
I use digital out into my MiniDSP flex - will soon put it direct into my avr.
Pop and click removal Magic) works well. Doesn't remove them completely but takes the edge off them making them much less noticeable. Ive not noticed any effect on the music. There will be new firmware in a few weeks with improved Magic function. I'm looking forward to finding out how much better it is.
This is one of those pieces that's a pleasure to buy.
So much so that I'm writing to them because I'll need a second unit; I bought another TD.
This device is very good; you get fantastic quality. As our friend above said, it removes click e pop well, obviously not all of it... especially since there are some very complex hissing sounds.
But it's a delight. I'm using the optical output on the EVO 150 and also the analog output; both work very well.
The optical output has the advantage of doing 24/96...
Excellent device with good support; they are fast and very helpful when I have any questions, responding in less than 30 minutes, at least with me.
Thank you, WaxWing.
Yes optical out into DAC is the best way to go imo.
There are a couple of noise reduction features - super mono which is a clever feature that selects cleanest channel in a mono record and uses that to output to both speakers.
Then there is the pop click filter.
If you play 78s, or collect in genres with often poor pressings like reggae or you have to take what your given like African vinyl then combining these features does have a noticeable beneficial impact on playback.
Hello!
Can you confirm that the Waxwing can be used as a line level DSP between a preamp and power amp?
Would it be transparent and have much lower distorsion and noise compared to the MM/MC input?
What about the noise from the 5V USB PSU?
Seems a bit odd to use a preamp with excellent PSU performance together with a mobile USB unit.
Can someone answer thise questions.
Thank You.
I have not tried it as this but None of these are a problem on paper, the vinyl medium are far worse than any of the issues you are concerned about.
The max output from Waxwing /Puffin is 2V , your power amp must not demand more if you want the full power range.
