Parasound Zonemaster 2350 Class D Power Amplifier with ICEpower 700ASC2
SEKLEM
Indiana
I’ve not had much to post recently since moving and just now starting to get settled. But the delights of having more space has been a driving force into research for more power and after weighing options and lying in wait for a smoking deal I believe I may have found exactly what I wanted.
The Zonemaster 2350 isn’t particularly handsome with a rather “system integration” aesthetic, but that is the target market. It’s almost the same size as the Niles SI-275, another system integration amplifier, I keep as a backup. The Parasound is a bit lighter than the Niles since it has no transformer or heavy heatsinking.
I’d read the 2350 sported some type of high power ICEpower module. Parasound’s published material would only say that it was a “premium class D amplifier stage”. In the search for class D amplifiers I arrived at ICEpower because they appear to be reliable and appear to use better parts in the manufacture of their modules, which lends to the longevity of their devices.
I’m a creature of habit, and I habitually hunt and wait for bargains. I keep saved searches and check them regularly. The Parasound popped up at a price I could live with and appeared to near new. Worst case if it turned out the info I’d read was incorrect I could at least recoup my investment.
Upon receiving the 2350 I popped the top and had a look around. To my joy, under the heatsink I was able to locate the model of the module, ICEpower 700ASC2, yippee! At the time of the ICEpower 700ASC2s introduction it was their most powerful integrated 2 channel amplifier board. I believe the 1200ASC2 now holds that position.
The 700ASC2 module is purported to be capable of delivering 350 watts per channel into 8 ohms and 700 into 4 ohms. These are Parasound HCA-3500 type numbers, and that amp weighed 88 lbs and required two separate 20 amp circuits to run at full power! Oh yeah, that’s more power than I’ll ever need.
The black square you see in the front right of the chassis is the heatsink that was affixed to the 700ASC2 module. I didn’t bother to photograph while I had the top off, although perhaps I should have. It was very difficult to see under the heatsink and I may not have been able to get a good shot of the module in any case. If anyone wants me to take pictures with the cover off, let me know.
On the business end there’s a bevy of useful features for numerous applications. The 2350 can serve as a subwoofer amplifier, has high pass filters, high and low level inputs, sub preout, loop output, 12v trigger with loop output, and A&B output. While the feature set is sure to curl audiophile toes, it’s doubtful the features do any real harm to overall quality.
I’ve been playing it for a few hours now and I’ve pushed it harder than the B&K Reference 125.2 S2 that usually resides in the setup. The Vandersteen 2CE Sigs definitely have more to offer dynamically with the 2350. I’ll continue listening over the week and if anything stands out I’ll comment on it, but so far it sounds like any other competent amplifier I’ve used, just with more power.
Edit: title changed
pozz
Слава Україні
Editor
I'd like to see some pictures with the top off.:)
Matias
São Paulo, Brazil
ICEpower now calls this module 700AS2, just renamed them. It is the same used in PS Audio Stellar M700, except PS Audio uses mono version (700AS1) and its proprietary buffer before the module. Wyred 4 Sound ST-750LE also uses this stereo module.
700AS - 1 channel driven.
Ron Texas
Wyred for sound uses an input stage to provide additional gain. The Parasound requires 2V to hit maximum power which is on the high side for an amplifier which only has unbalanced inputs. While a typical 2V unbalanced output of a DAC would seem like enough, the digital volume control will be so high that there is not enough headroom.
SEKLEM
SEKLEM
Indiana
I have an Adcom GTP-602 whose specs indicate 5v max output unbalanced, does this help mitigate that?
Ron Texas
That should knock the ball out of the park.
SEKLEM
SEKLEM
Indiana
Top cover off. Black plate is a aluminum and secured to the heatsinks of the ICEpower 700ASC2 board with thermal paste coupling them to add to the radiating surface. The plate also aids the prevention of dust buildup on the board.
This was the best shot I got of the model of the board.
ICEpower 700ASC2 2 channel amplifier with built in power supply
Bonus shots
SEKLEM
SEKLEM
Indiana
I probably shouldn’t try it. Using a receiver as a pre/pro and I can reach uncomfortable levels of output with the Vandersteens. I don’t think they can handle all the amp is capable of.
SEKLEM
SEKLEM
Indiana
At about 10:30 last night I was listening to the Interstellar OST. It had been a while since I listened to it and forgot how loud it can get. The Adcom doesn't show signs of struggle. The speakers are undoubtedly the limiting factor in output now.
SEKLEM
SEKLEM
Indiana
Sorry to span comments about this over the course of a month or so. I wanted to add a couple observations after reading @VintageFlanker's review of the ICEpower based Apollon AS1200 amplifier.
1. The Parasound 2350 gets a little warm to the touch after being on for a while, regardless of whether idle or under load. The difference in warmth is imperceptible to touch. A thermometer reading would likely tell a different story.
2. The 2350 makes no audible noises while operating other than a series of relay clicks when it comes out of standby. Light hiss from speakers (Vandersteen 2Ce Sigs 86 dB, 1 meter with 2.83 volt input). Some of that hiss could be due to the Yamaha RX-V659 that I'm using as a pre/pro.
GeorgeWalk
I have the Parasound 200 Pre and 275 v2 amp. I like them They drive my Klipsch bookshelf speaker with more than enough power and I think they sound great.
SEKLEM
SEKLEM
Indiana
I’d like to get a Parasound 2100 preamp for the bypass feature. The voltage needed to take the Parasound to full power isn't available from the Yamaha RX-659.
SEKLEM
SEKLEM
Indiana
The manufacturer specs for input sensitivity
2 Volts = Full output (350 Watts @ 8 Ω)
Total gain = 29 dB (Level controls set to Maximum)
What do you mean the digital volume control will be so high that there is not enough headroom?
Ron Texas
It means if you are using 3db of positive EQ at some frequency you lose that much in maximum volume without clipping. Someone else might be able to explain it better.
Zanollo
My apologies for posting to this old thread.
But I am considering either Parasound NewClassic 2125 v.2 or Parasound ZoneMaster 2350 for a 4 speaker (two room) setup together with a Bluesound streamer.
From what I gather is that the 2125 is a AB THX amp, and the 2350 is a D an not THX?
