it_iz_what_it_iz
- Joined
- Dec 1, 2022
- Messages
- 8
- Likes
- 0
DEVICE: Parasound HCA-2003 circa 1998 three-channel amp
SYMPTOM: 10+ seconds after power-up one channel's output voltage (as read by a DVM on the outputs) slowly starts to go unstable varying somewhat sinusoidally several millivolts positive then negative growing in magnitude to in excess of a couple of volts. (This, of course, can cause voicecoil over excursion/damage.)
ROOT CAUSE CIRCUIT BOARD: Don't know but have been able to swap leads and, with 100% certainty, isolated the culprit to be one of the far right hand circuit array on the Inputs Board. See pic.
ROOT CAUSE CIRCUIT/COMPONENT: I simply don't know. I've A-B-C's each and every component across the three identical circuits (for the three channels) using only an ohmmeter and voltmeter. Have found all NPN transistors functioning OK, all PNP transistors functioning OK, all diodes functioning OK, all resistors very similar in resistance, pots all very similar in min and max resistance, all pot's resistance vary smoothly and similarly with rotation, all capacitors ohm'ing out very similarly.
QUESTION 1: What am I not doing that I need to do to isolate and verify what component(s) out of spec?
QUESTION 2: What additional diagnostic devices (scope, signal generator...) might be needed?
