Parasound Halo A31 noise help...not sure what to check next
CrotalusV
Hi all - I did post this on Reddit, too, so apologize if some of you see it twice :).
Hoping some of the experts here can help with some ideas. I have a Parasound Halo A31 (3-channel, big toroid) driving L/C/R off a Marantz Cinema 30. There's an audible hum from the L/C/R speakers and I've spent a lot of time trying to isolate it.
First, to head off the usual first question: The chassis is dead silent. The hum comes out of the speaker cones. It's low-level — audible up close to a driver (ie. up to ~36" away, not intrusive at the listening seat — but it's clearly there and I'd like to understand it.
Characteristics:
  • All three A31 channels hum and before I got the A31, I was using my Marantz Cinema 30 on the same power outlet, speakers, and wires with no noise.
  • Volume-independent. Constant level no matter where the Marantz volume sits or if the inputs are even connected. Hum persists with shorted inputs.
  • 60 Hz-led, odd-harmonic dominant. Nearfield RTA with a UMIK-1 in REW, mains-related peaks: 60 Hz, 180, 240, 300, and so-on up to at least 1kHz.
What I've ruled out (none of these have delivered any impact to the hum):
  • Interconnects fully disconnected from the Marantz
  • Inputs shorted with RCA shorting plugs
  • Amp on its own dedicated breaker, separate from all other gear
  • Every other breaker in the house killed except the amp's circuit
  • All other equipment powered off
  • Safety ground lifted briefly with a cheater plug (pulled it right back out — not running that long-term)
The part I can't explain:
  • Took the amp to a friend's house on a separate electrical service — hum persisted. But both my place and his are on the same area utility company, we're about 4 miles away from each other.
  • A shop about and hour away bench tested and couldn't reproduce the hum at all. However - when I went to pick it up he offered to let me listen to it and there was so much ambient noise I couldn't tell whether the hum was there or not. This is inconclusive to me except that with no input, at the speaker terminals the V DC = 0.2mV which seems great. V AC was "essentially zero" according to the tech. Could this be possible even if the hum is present?
So the open question is whether this is (a) an intrinsic amp fault that just didn't surface on the shop's bench, or (b) an amp that's unusually sensitive to something on my electrical service (line harmonics / conducted noise).
My questions:
  1. Has anyone battled something similar and what turned out to be the cause?
  2. Anything that discriminates "faulty amp" from "amp + dirty mains" without just shipping an 80 pound box to Parasound's official repair shop across the country? I'd like to try anything and everything (within reason) to identify a local problem first.
Next test I'm planning is running it at yet another home on a different electrical utility company to see whether that kills it — which should at least separate mains-dependent from intrinsic. I also have the iFi DC Blocker+ on order to try out, just in case there is some DC on-board my mains.
This snapshot is using my UMIK-1 and REW from about 0.5" away from the speaker cone:
That's clearly mains hum in the graph.
The Marantz claims 140W per channel, which should be plenty without needing the Parasound, and you did say you had tried driving the speakers using only the Marantz and all was fine.....
It seems to me that inserting the Parasound into the chain could be adding a ground loop, or that it has an internal fault, possibly in its PSU (or a design error) that is allowing too much mains noise through. But....
You say that when the Parasound is alone with inputs shorted, you still get hum which tends to eliminate ground loops as a cause - so being brutal, I'd sell it and get a three-channel Class D Hypex or Purifi-based power amp if you really need more power (I'm sure the man at Buckeye can help if you are in the US).
My prediction is the iFi unit won't help - DC is not 60Hz, but a lot depends on how your house is wired - I would be glad to be wrong on this. I assume you can send it back for a refund if it does not help!
Welcome to ASR! Unless I'm missing something, that just looks like a ground loop. It could be mains hum from the Parasound transformer, but a ground loop seems more likely. Especially since the Marantz is a class II device (double insulated, no safety ground) and the parasound is class I. The idea that this could be related to mains "power quality" when you can see the mains freq plus harmonics in the measurements sounds weird to me. Clearly, you will never be able to find any powered mains outlet within the US which doesn't have 60 Hz present on it, right? :D
There are many possible solutions to ground loops. Not all of them work in every situation. The easiest would be to get rid of the Parasound unless you really need that additional power. Other options include switching to balanced interconnects, galvanic isolators for the RCA connections (essentially mini transformers, cheap ones are often problematic) or a copper cable connecting the cases of the Marantz and the Parasound (make sure to connect bare metal, not painted parts). The latter would be quick and easy to test.
"Unless I'm missing something, that just looks like a ground loop" - but unless I misunderstood the OP, the Parasound is claimed to produce hum into the speakers with its inputs shorted and no connection to any other powered device.....
I understood it in the sense that this relates to the Marantz'es inputs disconnected and shorted. The OP is ambiguous from my perspective, but you may be correct. @CrotalusV will need to clarify.
Google tells me the amp is likely about 14 years old. It possibly contains leaky power supply capacitors which are a likely culprit and can cause hum that is common to all channels.
Hi all - some points of clarification, and I really appreciate the attention on this!
@RandomEar , @Redacted - what I meant was amp inputs shorted, totally disconnected from any other device. In fact, every other circuit in the house flipped off at the breaker panel. So, @Redacted 's interpretation was accurate.
@raindance - this amp was purchased new in 2022. I bought it second-hand just a couple of weeks ago. The seller has been very cooperative and pleasant to work with, no concerns there. That said, I would like to make this amp work if possible. No reason that shouldn't be the case even if I have to send it to Parasound (or their repair shop) for repairs, it'll still be worth it.
Thanks all!
Howdy. Marantz 140wpc is with two channels driven only, and I am driving 9 total, hence the addition of the Parasound. Perhaps not totally required, but better for my sanity and satisfaction to not have to question it :).
I also predict the iFi won't help, but since it's returnable I figured why not.
OK. In that case, it won't be a ground loop. Just to be thorough, I would check the (external) mains cord and make sure that the safety ground is actually connected and that the resistance is close to zero Ohms.
If that's OK, it is probably time for a visit to the repair shop unless you would be tempted to take a peek inside. If you're willing to take the cover off, I would check if any line level cables are routed suspiciously close to mains ones inside the amp.
Reactions: MAB
Like this A31 interior:
It looks like Douglas Self was not consulted! ;)
This routing may or may not be the issue, but it looks wrong to me.
Judging by the chart and its harmonics with no signal, this looks broken to me.
Like, really broken.
Do you have a DMM to measure its outputs for DC?
Looks to me like an amp that needs repair. Could be leaky power filter capacitors, usually a pretty easy fix, and seems most likely given the amp is otherwise working and yet hums with nothing else connected.
