Parasound Halo A21 stereo power amplifier and P5 preamplifier review
pma
Prague
Intro
Sometimes we can read questions why more expensive "high-end" components are not tested at ASR. The reasons are obvious - there must be a piece available to be tested. Let me make a small try - a result of my short test dated January 2019, when I was asked by the Halo A21 owner to check his amplifier.
Parasound HALO A21
It was a nicely built power amplifier produced between the years 2002 - 2020.
Basic parameters per the manufacturer
  • Power output: 250 watts per channel into 8Ω (stereo), 750 watts into 8Ω (mono)
  • Frequency response: 5Hz to 100kHz
  • Total harmonic distortion: 0.2%
  • Damping factor: 1100
  • Input sensitivity: 1V
  • Signal to noise ratio: 112dB
  • Speaker load impedance: 4Ω to 16Ω
  • Dimensions: 445 x 194 x 485mm
  • Weight: 27.3kg
1. How it looks like
The amplifier is well built, as one can see from the following photos:
The case is heavy, with appropriate heat sinks and good craftsmanship. Not seen that often nowadays.
2. Some measurements
I have had no intention, and no idea, 5 years ago, to write a review of this amplifier. But, it is probably worth sharing.
2.1. THD distortion at 100W/1kHz/4ohm
THD = 0.0098%. Please note very low content of mains related spuriae from the linear power supply. It is my deep persuasion that it may result from operator's experience and knowledge how to setup the measuring circuit properly.
2.2. THD distortion at 328W/1kHz/4ohm
2.3. CCIF IMD 13+14kHz at 21Vrms 4ohm load
The result is very good, taking into account very high signal level - tested at more than 100W/4ohm.
2.4. THD vs. frequency
Measured at 10W/4ohm. There is a progressive rise of distortion with frequency, indicating to decreasing feedback factor with frequency. The result is not perfect, however not to be audible.
3. Conclusion
Parasound Halo A21 was a well built, rugged stereo power amplifier, reasonably priced in a class of high-end amplifiers. The parameters are respectable, with exception of distortion rise with frequency. I appreciated very low content of mains frequency related spectrum lines.
Note: more specs in the attached pdf
Pavel,
The bandwidth limit prevents seeing THD above 10K. Looked like there is a knee and it was decreasing at cutoff frequency.
OT, we really enjoyed Praha. Went the Holy Infant Church daily, walked 8 - 10 miles a day, and weather was great after first two days. That grade from Pyramid Hotel to Old Town builds character. Started using trolley.
George,
Yes, it was measured with 44.1kHz sampling. You can tell it from the H3 plot that finished at 7kHz. However, H2 was dominating at 10W. I can’t re-measure it, the plots are 5 years old, from my archive.
Glad to hear you enjoyed your stay in Prague. Me, I have returned home from vacations last Sunday.
There was a nice review of Parasound P3 + Halo A21 in "Australian Hi-Fi Magazine", with much more measurements, please find it below.
You have tested distorsion only ?
Of course, it's important, and the built quality is quite OK, but there are others parameters : noise floor, pops on /off, behavior on complex loads, etc.
Though Parasound is known for being a serious brand, I can't judge the quality on one criteria only.
The conclusion? Why is this particularly interesting?
It is analog I/O. It was only a brief check of the P5, all done 5 years ago. It was not intended as a review, as I have stated in the post #1, however I thought the info might be interesting, as it is a different category of audio components than that usually tested here.
I'm a bit uncertain why you did not extend your testing to 20K?
bump, any a21 owners out there that would compare the amp to any other amp with similar measurements? I'd like to know which measurements prove the chesty tone the a21 adds to the sound I don't hear with other amps.
What do you mean by compare, in what way?
Yes, compare in any way. I'd appreciate understanding which specific measurements represent that specific deviation from linearity the amp audibly displays.
I have one. Do you mean the sort of fat midbass or lower midrange?
My current system is a Parasound P6 ans A23+ based system ans its nice to find this review.
I might be missing something, I have not seen any specific measurements that represent the deviation from linearity you referred to. Audibly, I thought that amp was just transparent, how it would sound depends on my speakers, placement, and the source, if compared by subjective measurements, it sounded the same as my Bryston, Hypex, Purifi and Marantz amps but that's just me. The only difference was that I thought its transformer hum (not ground loop hum, but the big toroid's own hum) is slightly louder than my other amps, it was not audible from my seating distance but I could hear it is I was just a foot or two from it.
This is very helpful. I have this amp. 150watts at idle, reminds me to not leave it on, except in the winter :)
Miller Audio Research measured the original A21 extensively for HiFINews magazine back in 2011 (still available online). Their graphs show the amp has essentially perfect linearity across the audible bandwidth.
I own the same amp. It’s one of my all-time favorites among dozens I’ve owned. It has dethroned some considerably costlier amps.
I know the presentation you’re describing because these amps do indeed sound blatantly different than many others in that regard. After having owned 2 examples of the A21, modding them, and comparing them to dozens of others, I believe there are multiple factors at play: 1) The amp has incredible headroom as evidenced by the measurements. It can provide burst power of >1kW into 2 ohms. In my experience, amplifiers capable of the A21s combination of current and power capability tend to sound beefier in the lower octaves. This is especially true if the amp has a large linear power supply and employs judicious global feedback. Some of the more powerful Mark Levinsons, Krells, Pass Labs, Macs, Hegels and ATIs sound similar in the bass. 2) The amp produces a distortion profile more similar to what you would get from a good measuring tube amp, at least more similar than most SS amps you’ll encounter. It produces a fair bit of 2nd and 3rd harmonics, which I believe accounts for its midrange sounding a little fatter than what you often get from SS. 3) The A21 is a little “veiled” or less “transparent” sounding than many others I’ve owned. This is no more apparent than when comparing it to an amp like the Benchmark AHB2 or Coda No.8. It’s my hypothesis that its due to the A21’s decent but not great noise floor. This slight lack of transparency can make the perceived response warmer. The good news is owners can offset that some by pairing the A21 with an ultra transparent/quiet preamp like what I currently use, the Topping A70Pro. Biasing it a little higher than factory spec into class A seems to improve it too (subjectively).
All that said, I think this primarily comes down to current capability and headroom. Ultra powerful amps just have an “ease” to them that your circa 150WpC amps can’t match. Some of that comes from how well the amp controls the woofers, which does require a certain minimum of juice IME.
The A21 is an absolute beast of a classic, well-engineered AB amplifier.
OT. I have always had a spot in my head for CODA products. Thry were reasonably priced 30 - 40 years ago. California manufacturer, at least as well designed as Levinson, Rowland, and other more well known top manufacturers.
Knew someone who worked for the at that time. Brand must have been better known on the West Coast. The products were unicorns around here.
Would love to see measurements made with the test equipment available today.
