- Joined
- Jan 23, 2020
- Messages
- 4,336
- Likes
- 6,705
To *misquote the late Mitch Hedberg, “Paradigms are like Pancakes, all exciting at first, but by the end, your sick of ‘em!”.
I have one patiently waiting to be tested.I would love to see a review of the JBL Stage A130 some time.
This is a review and detailed measurements of the Paradigm Monitor SE Atom bookshelf speaker. It was kindly sent to me by a member for testing. It costs US $239 from Amazon including shipping for a pair.
I have to say, the Atom looks better than its price indicates:
Look at the nice grill over the tweeter and curvy smooth waveguide. Even the woofer seems like a step up from bargain basement with inverted dust cap and such.
The back naturally looks plain:
In case you are not familiar with Paradigm, they are a Canadian speaker company and a spin off of the research at NRC where Dr. Toole and Sean Olive worked. So similar pedigree. How well they follow that science is what we are going to examine here.
The system performed over 1000 measurement which resulted in error rate of more or less 1%.
Temperature was 60 degrees F.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter. In another measurement online I noticed they used the boundary between tweeter and woofer. Based on measurements to follow, I think center of the tweeter is the more correct one.
Paradigm Monitor SE Atom Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Looks like Paradigm is half married to NRC research. On-axis response is fairly uneven with a dip between 2 and 4 kHz followed by significant peaking and finally a bit resonance around 15 kHz or so. On the other hand, they do have good directivity in the way the three graphs follow each other in parallel. This will make equalization easier and room dependency lower.
Because the directivity is good, off-axis fortunately and unfortunately looks like on-axis:
So summing the two to get our predicted in-room frequency response has the same issues that we saw at the start:
Shame.
Here are the driver responses:
The port integration with woofer seems good. But the crossover is not as good as it could be, polluted likely by some port resonances. And of course we have that rising response from the tweeter.
Distortion data says what one expect in this category:
As indicated, directivity is good so our horizontal dispersion is good as well:
Here is our vertical directivity:
Seems to me if I had put the center lower, it would have fallen more in that 3 to 4 kHz ditch. So stay at or slightly above the tweeter axis.
Finally, here is our impedance graph showing multitudes of resonances:
Paradigm Monitor SE Atom Listening Tests
At first blush you get the impression of a highly detailed sound, nailing the "showroom experience." Continue listening though and gradually the brightness starts to be much. Everything sounds "exciting" for the lack of a better word. You can almost hear the "hiss" in the recordings. Or sensation thereof. So out comes the EQ tools:
Ignoring the 102 Hz one which is for a room mode in my listening space, the rest are basically eyeballing the on-axis errors. I initially did not put in the filter at 3000 Hz but was necessary as the brilliance was gone with all the high frequency filters.
Once there, I was pleasantly surprised by the fidelity of this little speaker. It produced very clean sound at elevated volume courtesy of no deep bass. This meant the woofer did not bottom out at all even on my "speaker killer" tracks. This does mean you need a sub though as there is no physical sensation for bass. Techno drums are fine but anything lower just doesn't get reproduced much.
My point of view of Paradigm is that they know the research. But they have also survived in the brutal speaker retail market for decades. As such, they have sacrificed some of what research says to compete on the showroom floor with likes of Klipsch. So not a surprise that the highs are accentuated. Luckily they did not throw out the science book and built good directivity into Atom. And provide very good tuning for bass to keep things from getting distorted and out of hand.
As is, without EQ, I cannot recommend the Paradigm Monitor SE Atom. With EQ, it is quite serviceable and likely superior to other speakers.
Have to drive 700 miles tomorrow to pick up something cool. That is lots of gas that I will be burning, making me feel pretty poor. So any donations are appreciated using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Paradigm Atom SE APO EQ LW 96000Hz
November252020-110610
Preamp: -1.7 dB
Filter 1: ON HPQ Fc 52.4 Hz Gain 0 dB Q 1.12
Filter 2: ON PK Fc 161 Hz Gain -1.95 dB Q 1.15
Filter 3: ON PK Fc 849 Hz Gain -3.06 dB Q 3
Filter 4: ON PK Fc 3404 Hz Gain 2.07 dB Q 1.63
Filter 5: ON PK Fc 7092 Hz Gain -2.81 dB Q 0.98
Filter 6: ON PK Fc 15120 Hz Gain -6.18 dB Q 3.54
Paradigm Atom SE APO EQ Score 96000Hz
November252020-110522
Preamp: -1.6 dB
Filter 2: ON PK Fc 155.5 Hz Gain -2.17 dB Q 1.24
Filter 3: ON PK Fc 851 Hz Gain -3.06 dB Q 2.76
Filter 4: ON PK Fc 3281 Hz Gain 1.91 dB Q 1.45
Filter 5: ON PK Fc 6794 Hz Gain -3.71 dB Q 0.77
Filter 6: ON PK Fc 15175 Hz Gain -7.96 dB Q 3.24
Maybe some day there will be decent Canadian speakers made here, eh?
This is a review and detailed measurements of the Paradigm Monitor SE Atom bookshelf speaker. It was kindly sent to me by a member for testing. It costs US $239 from Amazon including shipping for a pair./
That's a cool pic!The Paradigm 7se was my first introduction to higher fidelity speakers, so I’m glad to see a Paradigm reviewed here. I greatly preferred the Paradigms at the time to the Klipsch Heresy’s owned by another friend of mine. I remember the review of the Paradigm had a detailed sidebar that discussed the cause of “oil can” resonance in the tweeter. Perhaps that also afflicts this speaker as well.
BTW - That mailing label in the image is not mine!
Sorry but I don't understand this - wouldn't the sound you hear on youtube depend on the mic used to record the speaker, and more importantly the speakers you are using to listen to the video?Thank you so much for reviewing some cheaper speakers. I heard some youtube videos of this speaker and thought it sounded thin and bright. Now seeing the measurements it makes much sense.
I don't understand food reviews on youtube of fast food, but I watch a few and some people get MILLIONS of views for eating weird fast food like Krispy cream chicken samwitch. HAHASorry but I don't understand this - wouldn't the sound you hear on youtube depend on the mic used to record the speaker, and more importantly the speakers you are using to listen to the video?
Unfortunately, I see that as common practice...and not just in speakers.I wonder if speaker companies deliberately "mis-engineer" their low-end products to avoid cannibalizing on the market share of their higher-end products.
