I started getting into DIY audio as a way to save money, pass time, learn more, and increase my daily quality of life at home during the pandemic. This was rewarding and enriching, I can't imagine I'm the only one who started for similar reasons. Who else caught the DIY bug after being stuck inside for months? What are your builds? How do you like them? What have you learned?
I'll start with my Speedsters, not only the first audio device I've built, but the first box I ever made.
I'm shocked at what such a small package is capable of. They're not the cleanest or most neutral speaker, but they sound great. There's a slight V-shape to it's response, and a gentle, long bass roll-off. They come to life at a higher volume but are perfectly respectable monitors at normal listening volumes. It wasn't my first choice, I wanted to build the S2000s from DIYSoundGroup.com but ran into supply issues. I'll never know if I made the right choice, but I stopped thinking about it once I gave them a listen. Worth it.
After laboring over a box with portable tools, I cut my losses for the TV and went with a HiVi 3.1 build. After buying all the perfectionist crossover components, I said to hell with it and returned them. It's fine as-is.
I'm also very happy with these. The three way never struggles with details or clarity. I never feel as though I'm missing anything, besides the deepest sub-bass. I'm sure they'll be all I'll need for years. I just need to find a decent sub build... like, say... this Dayton 12"? A soft touch on the tone control knobs do good work, but it doesn't feel like a theater yet. Plenty for music, though. Wishing I had a better amp.
So that's mine, what have you all been up to since 2020 told everyone to go home and stay there?
