Panasonic RD-820 Turntable – Persistent Left-Channel Crackling (Need Help Diagnosing)
Typod
Hey everyone!
I'm hoping someone with more experience repairing vintage turntables can help me figure out what's going on with my Panasonic RD-820. I've been troubleshooting this issue for a while, and despite cleaning connections, testing components, and resoldering wires, I still haven't been able to resolve it.
I'm trying to determine whether I need to replace the RCA cables, repair the tonearm wiring, replace the cartridge/stylus, or look somewhere else entirely.
The problem​
The left audio channel produces crackling and distortion, while the right channel sounds perfectly fine.
The crackling is noticeable when playing records. The left channel still produces music, but the sound is accompanied by crackling that makes listening unpleasant.
The right channel sounds normal, with no noticeable crackling or distortion.
The turntable is connected to a receiver using its red and white RCA cables, with the receiver set to PHONO.
Turntable and equipment​
  • Turntable: Panasonic RD-820
  • Cartridge/stylus: Replaced approximately 1–2 years ago.
  • Connection: RCA cables connected to the receiver's PHONO input.
  • Issue: Crackling exclusively in the left audio channel.
I don't currently know the exact cartridge or stylus model.
Troubleshooting I've already completed​
1. Swapped the RCA connections at the receiver
This was one of the first tests I performed.
When I swapped the left and right RCA connections at the receiver, the crackling followed the turntable's left RCA cable.
The right RCA output sounds clean when connected to either PHONO input.
This makes me believe the issue is coming from the turntable rather than the receiver's left channel or speaker.
I also tested the receiver using FM radio, which sounded normal.
2. Tested the cartridge using a multimeter
I previously measured resistance across the cartridge's left and right channels.
My readings were approximately:
Cartridge channelResistance
Left (white and blue wires)469 ohms
Right (red and green wires)446 ohms
Both channels appear to have reasonable resistance readings, although I'm not sure whether the difference between them is significant.
My understanding is that these readings suggest neither cartridge coil is completely open or shorted, but they don't necessarily rule out an intermittent cartridge problem.
3. Cleaned the cartridge pins and electrical connections
I used electrical contact cleaning spray on the cartridge pins and the small connectors that attach to them.
I also cleaned the RCA connections at the receiver.
Unfortunately, this made no noticeable difference. The left channel still crackles.
4. Resoldered wiring
I've worked on the small wires near the cartridge/headshell and resoldered connections.
At one point, the small brass connector attached to the red cartridge wire had come loose. I soldered the wire back onto the connector and reattached it.
I've also worked on the tonearm wiring connections.
Despite these efforts, the crackling remains.
5. Performed a cable wiggle test
With a record playing, I gently moved and flexed the RCA cable to see whether the crackling changed.
I believe the crackling changes slightly when moving the cable. At times, it seems to become softer or slightly louder.
The change isn't dramatic enough for me to confidently identify a specific damaged section, but it makes me suspicious of an intermittent connection somewhere in the RCA cable or its solder joints.
I haven't conclusively isolated the fault to the cable itself.
What I'm currently considering​
At this point, I'm leaning toward replacing both RCA cables entirely, starting from their internal connection points inside the turntable.
My thinking is that replacing the old cables would eliminate the existing RCA leads and their solder connections as possible sources of the problem.
However, I don't want to spend time replacing them only to discover that the actual issue is inside the tonearm, cartridge, or headshell.
I'm also wondering whether the stylus could be responsible, although the fact that only one channel is affected makes me question that possibility.
Questions for anyone familiar with vintage turntables​
  1. Based on these symptoms and tests, what would you investigate next?
  2. Is there a reliable way to isolate the problem between the cartridge, headshell wiring, internal tonearm wiring, and RCA cable using a multimeter?
  3. Could a damaged stylus cause persistent crackling in only one channel while the other sounds completely normal?
  4. Would you recommend replacing the RCA cables at this point, or is there another diagnostic test I should perform first?
  5. If I replace the RCA cables, does the Panasonic RD-820 require a particular cable type, or can I use a good-quality, shielded, low-capacitance stereo RCA cable?
  6. Are there specific internal solder joints, terminal strips, or common failure points on this model that I should inspect?
  7. Could a cartridge develop an intermittent fault even if both channels show relatively normal resistance readings?
I'm comfortable using a multimeter and doing some soldering, but I'm still learning about turntable electronics.
My goal is to repair the turntable properly rather than simply replacing components at random.
I'd really appreciate any suggestions on how to narrow this down or what tests I should perform next.
I can provide photographs of the cartridge, headshell, RCA cables, and internal wiring if that would help.
Thanks in advance for any advice!
Too many words, sorry, but I would expect such a record player to have a muting switch for its cycling. It would probably be a normal microswitch. That is what I would look at if it is not the cartridge itself or the arm wiring or any of the interconnections.
The cables or the pin and shield are ALWAYS prime suspects until ruled out... ok, I did read a little of your post ;)
(...) Based on these symptoms and tests, what would you investigate next? (...)
Swap R+ (red) & R-/RG (green) and L+ (white) & L-/LG (blue) at the cartridge output pins. Serves the same purposes as the channel swapping at the phono inputs, just now at a different spot, so you can check, whether the crackling already comes from the the cartridge or is rather caused somewhere downstream.
Oh, and the measured resistance difference between the two channels of the cartridge wouldn't seem unusual. Might be a good idea to measure both at the output pins of the cartridge and at the output plugs of the phono cable, though, so you can compare the results.
Greetings from Munich!
Manfred / lini
Manfred / lini
While a good suggestion - with a cheap multimeter I'd be careful - a little "hot", on the resistance setting. I think mhardy6647 has the problem nailed.
Since we don't exactly know the cartridge, a little precaution goes a long way. My 800.00 tester does not feel like 9V, leads on the tongue - I can hardly feel it -
my cheap "burner" tester - yes. Definitely sort of hot.
Cheers
Hey thanks for the reply! I'll be honest, I have no idea what a muting switch is or where its located? I would assume its near or on the "motherboard" of the record player. If this is a cartridge or arm issue, ill either have to fix it myself or trash it because I cant find parts for this thing anywhere.
Would I have to replace the muting switch or look at the wires to see if they are oxidizing or from old age?
Attached are some photos when i was taking a look at the head piece. Not sure if you can see anything from these.
Cheers
I have a cheap multimeter and it was like my third time using it, I attached pictures of my cartridge. I know there is a bit of age in it and oxidation.
Manfred / lini
I pulled the wires and one of them broke when I tried to install it again, and I'm not great at soldering and it was difficult to put it back on, this might be a later test not sure yet. I might just pull the whole arm and see if I can find anything there before I pull those wires again.
Well, this is quite like the Dual headshells, sadly - if time is not an issue - I would be glad to help out. I'm in Florida, close to Sarasota.
I am The Turntable Clinic, labor of love really - since I can't charge for the work that I do put in. Easy enough to mail that to me, and I'd mail it back.
Send me a message, if that is something you'd like to consider. You find me on Google. I wouldn't charge for something like that.
Cheers
Do you have access to spare cartridge to test ?
Cheers
Im not sure what you mean and what might be the issue. I might consider your offer but i want to see if I can fix it first
Well - you said you disconnected a lead and you are not that good at soldering. If you have difficulty with discerning headshells - Google Dual headshells and compare pictures.
Even with one lead broken you can test single channel alternatively. This will sort out if problem is in the cartridge itself.
I've had some luck with some older turn tables cleaning the input slots, a Q-tip and some isopropyl alcohol 99% very gently. It might be straight the wires though my friend.
