Hi everyone,
This is a question for UB9000 owners in PAL countries (I am in Australia)....
Have you been able to get PAL DVDs or 50i blurays to play properly? I am finding that the machine converts them to 60fps before sending them to the TV, even if I have the "TV System" setting on "PAL". Most TVs in Australia technically support both PAL and NTSC signals, but the unnecessary conversion to 60fps within the UB9000 results in jerky motion. (The manual even warns that "PAL discs cannot be correctly played on an NTSC TV").
My old Oppo has no problems outputting PAL/50i discs at 50fps and they play just fine on the same TV. Apart from lacking 4K support, the Oppo is getting old, so keeping both devices going in the long term is not an option. Besides, the Panasonic player is supposed to be able to play PAL/50i discs in this country.
I have been through an exhaustive troubleshooting process and have become convinced that there is a problem with the firmware. To test this theory, it would be great to hear from other UB9000 owners in PAL countries. Have you had the same issue playing PAL DVDs or 50i blurays on your UB9000? If not, does your TV support 60fps material?
Thanks very much!
Thanks very much!
