And these sweet mixing engineersmixing engineers work with) may have more than 20db crest factor
The audiophile aversion to the use of compression continues to astound. All your favorite records (yes, even the classical ones) use some kind of dynamic range control.And these sweet mixing engineersruincompress recordings so that the listeners' poor speakers don't get ruined?. Ugh.
Dfuller : No, it isn't. We use dB(C) or even unweighted for that.
So true. Trust me, you don't want to listen to an acoustic drummer 1 meter away full dynamic range for a full live performance.The audiophile aversion to the use of compression continues to astound. All your favorite records (yes, even the classical ones) use some kind of dynamic range control.
Thank you for the update! Actually, more people found Orbit's HF is not as clear as Genelecs., but, the bass is what I am looking for. Great work!Recieved mine today. I have been having trouble integrating a single subwoofer (localisation problems even with agressive XO filtering) with my existing pair of Genelec 8350's (for sale here!). My original plan was to build dual subs as stands underneath my Genelec's. I decided to give these a shot while I was finalising the subwoofer details, but now I have changed my mind again. I will leave subjective comments until later but a few standouts for me so far:
1. Great imaging and soundstage width.
2. Impressive bass for the size. My room has two modes 54hz and 28hz. 54hz is around 10db naturally higher than the rest of the response, 28hz is around 5db higher. Two cutting filters here, and one at 200hz means I have now gained quite a lot of headroom to work with. In the current setup, there is more bass on offer at higher levels than I plan to listen at.
3. The HF isn't quite as clear as the Genelec's.
Below I have attached some REW measurments. The first is the raw response of the Palmers, the second is the Palmers with 4 PEQ filters. The third is the Genelec 8350 + single sub vs the Palmer. You can see the Palmer is slightly smoother around 100-200hz, and 1-2khz where the Genelec's exhibit some dips.
If I wasn't restricted by volume levels (apartment living) I would probably go Genelec + dual subs, but for now for this setup, I'm impressedth
Also seen on the cumulative spectral decay graphs. Lately I've come to be extremely skeptical about speakers claiming to extend well down in the lower frequencies that use a medium sized woofer. Usually this is accomplished by the use of a port but at the price of hideous resonances. IMHO this speaker, despite it not having a port, still exhibits subpar time domain characteristics.It just shows that physics still rules. With DSP you can get deeper bass but at the loss of clean SPL.
From my very subjective viewpoint, they don't cut quite as sharply as the Genelec's. You can see from my REW graphs the Palmer's have a slow roll off above 10khz, where the Genelec's extend flat-out.Thank you for the update! Actually, more people found Orbit's HF is not as clear as Genelecs., but, the bass is what I am looking for. Great work!
what is your setup? room, distance, toe in/out?From my very subjective viewpoint, they don't cut quite as sharply as the Genelec's. You can see from my REW graphs the Palmer's have a slow roll off above 10khz, where the Genelec's extend flat-out.
3.2x6m room, located around 50cm from the rear of one of the long walls. REW room-sim tracks pretty much exactly the measured in-room response. I have a thick 10cm absorber behind me. I sit around 2.4m from the speaker fronts. Toe'd in around 20 deg to face the listener.what is your setup? room, distance, toe in/out?
very similar to my room in an apartment. how do you compare Orbit with 8350+sub, the accuracy, imaging and soundstage.3.2x6m room, located around 50cm from the rear of one of the long walls. REW room-sim tracks pretty much exactly the measured in-room response. I have a thick 10cm absorber behind me. I sit around 2.4m from the speaker fronts. Toe'd in around 20 deg to face the listener.
An aspect worth mentioning is the rear radiation is much less than on other speakers I have used!
I don't deserve the lofty title of audiophile!)) I listen to far more black and doom than classical music. Let some dynamic control exists, but compression is usually overused, IMHO.The audiophile aversion to the use of compression continues to astound. All your favorite records (yes, even the classical ones) use some kind of dynamic range control.
Too early to say really. I was however not happy with a single subwoofer no matter the position or XO filter used. It always had a detectable location which I hated. The bass from the Palmers is much better in this regard.very similar to my room in an apartment. how do you compare Orbit with 8350+sub, the accuracy, imaging and soundstage.
I couldn’t agree more. I was planning on measuring my Orbits and post my experience with EQ and Dirac ART in my 4.4 system but I discovered that my current front speaker position is in a null and I need to figure the best position. Hopefully in the next few weeks.
Do you thinks you have enough headroom with the 400watts per speakers in appartment ?Recieved mine today. I have been having trouble integrating a single subwoofer (localisation problems even with agressive XO filtering) with my existing pair of Genelec 8350's (for sale here!). My original plan was to build dual subs as stands underneath my Genelec's. I decided to give these a shot while I was finalising the subwoofer details, but now I have changed my mind again. I will leave subjective comments until later but a few standouts for me so far:
If I wasn't restricted by volume levels (apartment living) I would probably go Genelec + dual subs, but for now for this setup, I'm impressed.
EDIT: I will also add the unboxing experience was nice. The speakers are put into bags with handles either side for easy removal from the boxes. The OLED display ontop is also very nice.
2 Orbits for the Fronts, 2 Kef Q150s for the surrounds, 2 SVS SB1000 (Non Pro) and 2 SVS 3000 Micros. This is in a 3m by 2.1m room.Would this be 4 Orbits + 4 subwoofers?
Just realized that for 5800€ one can get 5 Orbits + Denon AVC-X3800H + Dirac ART bundle.
Probably no sub needed with 10 x 8" woofers. And ART should tame room modes well with 5 fullrange speakers.
5800€ happens to be the price for a pair of ASCILAB C8C from Audiophonics.
I have a jacket of a similar color!)) But the room is a little bigger.I have
I have about 100 watts for each subwoofer, after which a natural limitation appears (link in the signature), less for the midbass, much less for the tweeters. In appartment.400watts per speakers in appartment ?
Right.To my knowledge, both AES and EBU recommandations uses dBA. dBC is usefull to complement dbA above 85 dB for live max volume limitations since they have been huge excess in the bass range with dbA only and the law has been forced to adapt in 2017 in France for example. But if you have sources that show the opposite, i will be happy to correct my point. (i've done some resarch to recall my previous readings but can't find any free doc).
What track is this?Amir's bass track reference from the review
I believe a Palmer employee already commented on this here in the ASR, stating that the driver is an in-house development.Could it be that the subs and the Orbits share the same speaker?
