Audionaut
I don’t know if all manufacturers handle it this way. If they do, it’s a very clear sign to me that there’s a lack of appropriate standardization for the end consumer.Max SPL is imho the most fudged spec of them all , all manufacturers do this
Personally, I’m not a fan of DSP that tries to alter a driver’s “natural” frequency response too drastically—regardless of Palmer, since many manufacturers do this now.
It is still not possible to consider the parameters of sound pressure, low frequency, diaphragm area, and enclosure size separately from one another, even though many would very much like to see that.
If you want to achieve around 25 Hz from an enclosure like Palmer’s, this is only possible with a massive boost of the frequency range via DSP.
Because this contradicts the natural physical behavior of the driver, severe distortion occurs even at very low levels.
That’s not something I’d enjoy, which is why I exclusively use very high-power PA woofers with a very high displacement volume and large diaphragm area in the low-bass range, housed in enclosures that function flawlessly down to 30 Hz even when passively tuned.
In my opinion, this is the only method that works physically cleanly and in which the driver can be perfectly adjusted via DSP within its natural limits. In living spaces ranging from about 40 to 100 square meters, natural frequency responses emerge starting at 20 Hz, and their peaks can now be very effectively reduced via DSP.
I try to avoid boosting the frequency response across all frequency ranges, because in my experience this can lead to unpredictable, often exponential distortion where one would have expected a more linear distortion curve.
So yes, I agree with you, and I would like to see sound level specifications for loudspeakers standardized much better than they are today.
For example, by specifying sound pressure at a certain distance, with a certain level of distortion at a specific frequency.
In my opinion, it would make sense to specify the sound pressure in each octave.
Then you’d see that a speaker only reaches 80 dB of sound pressure at 30 Hz with the desired distortion, and 116 dB at 1 kHz, for example.
The speakers I like can still reproduce 25 Hz at 116 dB from a distance of three meters, but my standards aren’t necessarily in line with industry standards.
