It's the same measurement as shown above with the spl graph.thank you for sharing! one question, at what spl did you measure the distortion?
Sound & Recording (Anselm Goertz) has measured the 944K1
I have a hard time believing that Geithain—who doesn’t publish any standardized measurements—could somehow perform miracles with a 32 Hz cardioid design using a purely passive system. So yes, for me, until proven otherwise, it still looks like snake oil.
Palmer did however create an unique (to my knowledge) passive cardioid implementation including top/bottom slots for vertical directivity control.
Search youtube for "stoneeh Palmer Orbit" for the videos comprising his measurements.Could you please post a link to the Orbit's compression measurement at 106dB?
Somewhat similar but not the same thing. At higher frequency the Orbits utilize the midrange cone and extended waveguide shape in the front baffle for dispersion control. When it comes to passive cardioid by rear ventilation slots in the enclosure, I haven't seen top/bottom slots before.MEG also have cardioid midrange, at least in some models. Those having a midrange in front of the woofer in some kind of semi-open baffle arrangement with a flow resistor ring. In my understanding, this is basically the same thing that Palmer does, just considerably higher in frequency range.
So, like 78dBSPL equiv at 1m?
Depending on whether the distortion measurement compensates for response, (per Temme's method), the peak at 100Hz might not be meaningful -- there's a big null at 100Hz in the frequency response. Distortion measurement with room reflections tends to be messy, harmonic frequencies aren't affected the same way as fundamental frequencies.
That's what is in my review, albeit, in a very large space and with the speaker elevated (almost floated) 5 foot high. So some room effects, but not a ton.Hope we will also see unechoic measurements from Erin.
Your HD measurements are much cleaner indeed. Still some small peaks are probably room-related.That's what is in my review, albeit, in a very large space and with the speaker elevated (almost floated) 5 foot high. So some room effects, but not a ton.
Thanks! Though I'd be careful comparing compression results across very different measurement setups and potentially test methodologies.Search youtube for "stoneeh Palmer Orbit" for the videos comprising his measurements.
96dB Compression:
106dB compression:
The subs don't have the issue, as they are mounted directly at the stonewall, 4 in total (2 in the front, 2 in the back), to avoid sbir. With the LS50 I used the 140 hz crossover for that. The speakers itself have a distance from their backside to the wall of 35-40cm.It's intresting that the sub doesn't have these issues at all.
Probably due to different position. An advantage that subs will have in many cases.
@Paffi What's the distance between the rear of the speaker and the wall?
Would love to see what happens with the Orbits backside right at the wall. Frequency of the notches will shift upwards and hopefully some notches would be less deep.The subs don't have the issue, as they are mounted directly at the stonewall, 4 in total (2 in the front, 2 in the back), to avoid sbir. With the LS50 I used the 140 hz crossover for that. The speakers itself have a distance from their backside to the wall of 35-40cm.
If SPL is measured with a quick sweep the limiter may be activated at one frequency and stilll be active at subsequent frequencies due to long release. Slow sweeps or sine burst testing avoid this but the former can cause thermal compression.
Moving Microphone MethodThank you, to ask.... how do you all ABX/Level Matching these relative to a Passive Speaker/Amp/Cable combination?
Thank you, @staticV3, would you suggest that this method supercedes the Measure or that the Measure is sufficient to derive/interpolate this method. Many will not have the Tools to perform this method (or expertise), will they?Moving Microphone Method
Then in Room EQ Wizard plot the level difference via Trace Arithmetic -> A/B
Zoom in, read the dB offset, then add it to one playback chain to compensate.
Remeasure to see the residual offset, then either readjust or if you're content, note down the remaining offset to give validity to blind test results (if that's your plan).
I don't understand. What measure?Thank you, @staticV3, would you suggest that this method supercedes the Measure or that the Measure is sufficient to derive/interpolate this method.
REW is free and the microphone can be extremely cheap.Many will not have the Tools to perform this method (or expertise), will they?
