Pro audio is such a wide topic , there are many different needs . I'm sure the pro people know their needs and this product fits right into some uses cases and other not so much ?
how is that a problem?There's a problem (maybe somehow) on Orbit 11 is that:
It can only provide 28Hz bass when you push it no higher than 84dB.
Anything beyond 84dB will cause it to lose low-end bass.
If you push it to 100dB (possibly not this high), the -3dB could be somewhere around 45Hz or 50Hz.
How is it not? It's a limitation. Some might want more.how is that a problem?
Electronic music can reach below 30Hz, and it does sound awesome when it does!For music mixing, 28 hz extension is already mainly overkill, the B of a 5 strings bass is 31 hz (and rarely played), and the A0 of a grand piano is 27.5 hz (and mostly never played). As i often say, for mixing : a clean bass extension to 40 hz (the E string of a 4 string bass) will be enough for 99 % of relevant work .
I don't see this as a problem either, in Dirac ART I can set the support level to 50hz which is good enough for me because I use 4 subwoofers and I suspect will work well with Orbits as Atmos speakers and localising bass.There's a problem (maybe somehow) on Orbit 11 is that:
Reckon they may well be if Palmer expands their range with more high quality products. Especially if they eat into their market due to better value for money.I doubt they are very worried.
Gonna disagree, at least Genelec. They are highly differentiated and have entire environments and systems into which customers buy.Reckon they may well be if Palmer expands their range with more high quality products. Especially if they eat into the market due to better value for money.
Then they aren't worried about it.Yes, but that's not the whole market.
I'm responding to your assertion. Are you not held to the same standard?Reckon they may well be
I did not assert anything. I said that they might well be concerned. You seem to be insisting that you know otherwise. I am asking how you are so sure.I'm responding to your assertion. Are you not held to the same standard?
I'm gonna let this go. You are equivocating.I did not assert anything. I said that they might well be concerned. You seem to be insisting that you know otherwise. I am asking how you are so sure.
good talkSplendid!
The issue isn’t the speaker itself. It’s simply that achieving a room with a clean, flat time‑domain response all the way down to 26 Hz is extremely difficult. That’s the paradox: you get an amazingly affordable full‑range monitor, but it ends up requiring a room that almost none of the people buying it will actually be able to have.
And of course the speaker’s low‑frequency extension affects how it excites room modes. Pretending otherwise is unrealistic. Of course, all full‑range loudspeakers will run into this issue. The difference is that they’re usually very expensive and therefore mostly used in professional setups with proper treatment, not in bedroom studios. That’s exactly why the Palmer Orbit 11 may create challenges that are far less common in typical home environments.
Applying a high‑pass filter is not consequence‑free either—especially if you do it with a FIR high pass filter, because you’re adding significant latency just to remove bass you don’t need.
