- Joined
- Jul 12, 2024
- Messages
- 2,760
- Likes
- 4,225
They are joking.How do you know?
How do you know? (sorry, had to do it)They are joking.
I have a finely calibrated sarcasometer.How do you know? (sorry, had to do it)
Red One Music here in Canada sent me this:That’s what concerns me, actually. I have a pair on order, since early last month, which might not show up now in USA for months. If I cancel now, what might the price be later if I try again?
Aside from subjectivity, aesthetics, pricing and distribution questions, other sleights may includeAluminum, coaxial, good sound, and reasonable price
So what's the catch?![]()
Who'd have thought that any speaker might not be perfect in every way?Aside from subjectivity, aesthetics, pricing and distribution questions, other sleights may include
Possibly audible group delay
Directivity beaming ~150hz (did I make that up?)
Fixed crossover at 80hZ
Normal Spl limits of this size
Somewhat Narrower directivity according to taste
I'm not bashing here. This is an impressively miniscule list.
What are you comparing that to? +-60°is 20% wider that the the non-purifi Ascilabs (+-50°) that are rightfully lauded here. The wider directivity is one of things about Orbit 11 that interest me.Somewhat Narrower directivity according to taste
The largest openings in the enclosure are those of the side woofers, so I assume that this is where access is easiest, unless the chassis are glued in place, which I can't imagine.Can not yet imagine how they do that, but it's amazing.
I think at 1m distance the soundstage is somewhat compromised. Even with KEFs the soundstage improved significantly when I put these speakers in my main living room at 2.5m distance.How's the soundstage, instrument separation?
The high-pass filter can be toggled and is disabled by default.So I guess these would not be compatible with dirac art? Or is there a full range option?
- Tons of low-end. In fact, my main problem now is having too much low-end in my small untreated room. I tried to play with the low-end EQ, and even -6dB is too bassy. I will connect the Wiim streamer later and will try to enable a high-pass filter around 35–40 Hz.
- There is some rather audible hiss at 1 m. Nothing super annoying, but it is there.
Yes and yes.Out of interest, were you able to get both of those things you mentioned improved? (the latter by using the pad reduction)
Because they're not sold out everywhere. For example https://www.andertons.co.uk/palmer-...ogle&utm_medium=organic&utm_campaign=surfacesHow did some people here got a pair if they're sold out everywhere ?
They stopped hesitatingHow did some people here got a pair if they're sold out everywhere ?
I don't have a crystal ball, but I assume they are sold out partly because people here got a pair.How did some people here got a pair if they're sold out everywhere ?
BrilliantHow did some people here got a pair if they're sold out everywhere ?
Yes and yes.
I dialed-in a HP filter in my Wiim streamer. Still plenty of impactful bass but without excessive boominess.
The pad reduction helps to tame the hiss a bit. My previous report was with -20dB pad already activated. I don't think there is a way to eliminate the hiss completely.
