mariodorianc
- Joined
- Feb 12, 2026
- Messages
- 5
- Likes
- 5
I have noticed some hiss in an ultra nearfield setting, with no pad: small room, on the dead side, Orbits at ears level, less than 1m, I definitely hear the hiss and would not keep them at that distance because of it, if it didn't have a pad.Can someone that has the orbits cofirm.. my units make a very loud his very noticeable at aroun1.3m to 1.5m becomes annoying.. happens both ub the studio and at home.. i have al cable with ferrite bits, they all roland fron roland store and they worked well with the solo6 never had a his.. can someone tell if my units are faulty..
Those measurements in your screenshots don't seem accurate, or at least not without context.aren't this group delay graphs looking worse than the one @stoneeh measured in his yt video for the orbits 11?
Notice the Genelec 8331 has a linear phase option with much lower group delay (I think you need GLM to activate that).Those measurements in your screenshots don't seem accurate, or at least not without context.
There appears to be an offset, which might be the system latency?
If that is the latency, then adding 5ms the group delay of the 8331 would still exceed one cycle which seems quite a lot.
The 8C would have huge latency (but little group delay), that would be noticeable in use. Is it really that bad on a speaker that expensive?
Huh, well then they are accurate and just really bad.they are from erin's reviews
The audibility of group delay, especially at low frequencies, is not settled science. In addition the whole "1 to 1.5" cycles is nothing more than a rule of thumb without any rigorous testing. The safe assumption based on testing that is out there is that Group Delay by itself is not particularly audible and is more of an issue for subwoofer integration. In any case the group delay for the Orbit 11's is in no way alarming and in fact is quite well behaved for a small speaker and is not much different than some dedicated subs, see subwoofer test article link. https://www.audiosciencereview.com/forum/index.php?threads/i-measured-10-subwoofers.49042/10ms at 100hz is right at 1cycle, which is just beginning to be audible if we go by the 1.5 cycles is audible theory.
I sent a reminder and the rep said he is going to check in with the US company. That's all I know.hello @amirm can you tell us please if you have new informations regarding when you will be able to fully review the Palmer Orbits 11?
thank you
Man, of course we have to ask this, but talk about an unfair comparison... Desktop monitor vs. 4-way Tower at 10x the price...how do they compare to the Salon2?
Yes and if you follow and read those threads there is no consensus and no agreement even among the experts about the audibility thresholds of group delay which makes it very difficult to interpret group delay measurements and frustrating for a hobbyist to know where to spend money. It is easy enough to eliminate virtually all group delay with large subs (both large drivers and large enclosures). A big source of group delay is strong high pass protection filters for "too small an enclosure" consumer subs pushed with too much LF boost. The questions is, "is the juice worth the squeeze"?If it’s audible, it's in low frequencies. We have a few topics about it 'Does Phase Distortion/Shift Matter in Audio? (no*)' https://www.audiosciencereview.com/...se-distortion-shift-matter-in-audio-no.24026/ and 'Audibility of group delay at low frequencies' https://www.audiosciencereview.com/...ility-of-group-delay-at-low-frequencies.8571/.
I have yet to see speakers in this price bracket that do better. And even (much) more expensive ones. I wonder what the bar is here?maybe audible group delay/ phase distortion in the bass.
I wouldn't necessarily call it a catch, because every speaker is a compromise and you always have to choose which compromises to make and where to set your priorities.In other news I guess we've found the "catch" with these speakers... Relatively high self noise and maybe audible group delay/ phase distortion in the bass.
