Hey Guys,
love to see the discussion and interest! Amir and I are in contact and we're trying to send him a pair as soon as possible. As the availability in the us usually takes a little longer than in europe we're trying to find the fastest way for you guys.
Thanks also for the kind words I read in here. If somebody is ever close to our headquarters hit me up and I can provide a tour through our showroom, labs (semi-anechoic chamber, etc.) and the rock'n'roll library.
In the meantime I'll try to answer most questions as best as possible. Please bear with me, when this sometimes takes some time.
1. Yes. 2x 250W, 1x 500W
2. Yes, the latency is a little less when AES is used as input. We estimate it's around 0.3ms less. But will test it for you.
3. Yes they are in seperated sealed boxes. I will post an inside view for you.
4. Yes. Palmer always grants 5 years warranty. This would be handled through your dealer, which will most likely than contact us.
1. Correct. Closed enclosure for the bass drivers, and and slit vents on all four sides to serve cardioid for the coax.
2. The Amplifier and the Power supply ist cooled via the aluminum housing. We use the whole enclosure for it.
1. It´s Service Port for service Duty only. We try to keep products easy serviceable for sustainability and longevity reasons.
2. Yes, the Pad controls the AES input Signal as well
3. No, the screws on the bottom are holding the SMPS in place, but you can remove the Feets and cloud use the mounting holes for a custom solution
4. No
5. The front light is always on, as it is the indicator for power status and the limiter (if active). The top lights of the control panel turn off automatically after 20s
Yes, the graph is smoothed.
One goody for you: That is the inside of Orbit 11
There you see how we packed everything in the very limited space of the enclosure. And you can see highlighted the sealing wall between the mid-/hi-drivers and the enclosure for the woofers on the sides.
