Palmer ORBIT 11 Cardioid Coaxial 3-way studio monitor (MSRP 799€/899$)
Hello ASR.
This is my in-depth review of the Palmer Orbit 11.
Enjoy!
Your PIR response suggests they could sound a little bright in some setups. Any thoughts on this from your experiences so far?
Hey im considering buying 3 of these for an LCR in a home theater (OFC crossed over to subs) at a 3.5m Listening distance do you think they would suffice ?
i know very little about cardioid speakers, would this be suitable for very nearfield? (PC desk setup, 0.5-0.7m listening distance)
Awesome work on the review, very helpful and as others have said, this seems like as much as one can do without a klippel. And nice job getting the scoop on independent robust measurements of this one. :)
To my eye I don't think this speaker is "perfect" - (but damn if they didn't get close with their first monitor)... the constant directivity isn't truly constant (although I've yet to see a graph of "CD" that I couldn't nitpick) and I would also expect it to sound a tad recessed in the lower mids or forward in the lower treble, depending on how you want to say it. That said, I was kind of expecting there to be more of a catch to this deal. The distortion looks quite impressive given the size and the overall frequency response is hard to criticize beyond it not having much of a slope down.
Since you can easily EQ in a downward tilt if you want it without fighting any of the (barely extant) directivity error, I don't see that as a reason to think twice...
My wife is going to be pissed, but I really can't help but think of getting a pair now... the "but these ones are white and look nicer" angle has worked before. We'll see...
Hypex is also a small medium-sized company.
Yes, excellence does not depend on the number of employees, but on their potential.
I just wanted to point out that they do not have unlimited funds and financial resources.
PS
Just for fun, here are a few of the big players in the audio and consumer electronics market for comparison.
Samsung Electronics employs around 260,000 people and generates annual sales of over USD 300 billion; its audio subsidiary Harman International has around 30,000 employees and sales of around USD 10 billion.
Apple Inc. has approximately 160,000 employees and sales of over USD 400 billion. Sony Group Corporation employs around 110,000 people and has a turnover of around USD 90 billion.
LG Electronics has approximately 75,000 employees and a turnover of over USD 60 billion.
Yamaha Corporation has around 28,000 employees and an annual turnover of a few billion USD.
This is really apples and oranges, I would guess Harman is probably the largest audio division in the world and it's probably not close.
The audio companies I've personally interacted with (that didn't own factories) tended to be pretty small shops. AFAIK more than 100 people puts you in a fairly high tier for audio, especially hi-fi or studio stuff.
How many people work at Genelec (linkedin says 213) or Mackie (linkedin says 187)? I think those are more informative comparisons.
If anyone wants to know the rubber feet base lateral distance one to other 17.2 cm(further back), and 18.4xm(on the further front) from the front feet to the bottom front baffle is 3cm.. i decided to let the baffle off the speaker stand..
These are not apples and oranges, but different company sizes in similar business areas.
It is simply not reasonable to compare Palmer, with its approximately 10 employees, with large corporations such as Harman, Sony, or Yamaha.
I know many small audio companies with very good reputations. One of them, not yet tested on ASR, is in my immediate vicinity.
Durian is my favorite fruit. What can I say...
I would also argue that mixes have gotten much worse on average in recent decades due to plummeting budgets for the pro productions leading to loads of shortcuts that won't stand the test of time and an increase in DIY productions...
Anyway, great to see these measurements, and thanks for sharing. How is the depth and width of the soundstage?
I hesitate even bringing personal opinion into this.. but, short answer, I listened to them indoor in a small room and outdoor, and no, no particular sonic character stood out to me in either scenario.
@stoneeh I suppose data below 100 Hz couldn't be captured reliably?
@dfuller 1% not 3%
Correct - the Orbit wasn't able to produce SPLs high enough below a 1% THD limit in the lower bass region that would allow the SNR to be good enough. I was able to perform a 3% THD measurement in the bass region, which then however began matching the 1% curve in the mid and high frequency region due to the Orbit's limiter protection circuits kicking it, so I only performed it up to ~600 Hz.
This is the 1% curve from the video again, and the 3% one in green:
While we're at it, something that slipped my mind including in the video - compression behavior. This is compression at 96 dB, vs. a reference level of 76 dB SPL, with the ~2 second duration sine sweep used for the rest of the measurements:
And a measurement that I performed late last night for the S/PDIF to AES issue; I cite:
I did get a signal, only it was very weird in that the Orbit then had a skewed frequency response, in that it had a high frequency rolloff. Dunno what that was about. Since that made the speaker unuseable, I declared the AES/EBU via S/PDIF connection attempt a failure.
This is the difference in frequency response from analog (normal behavior, used for the measurements in the video) to AES via my S/PDIF interface:
I tried a different cable (normal XLR cable with 0,5m length) too, I tried at different volumes, I tried switching the input setting from both AES channels summed to only left or right; all didn't make a difference. No big deal for me personally, but nevertheless something to document. Oh, and the interface used is a DSD TECH SH-AU01A, which works fine for me on other devices with AES input.
Stoneeh, your description said measurents were made at 2m? Is that also true the for the above distortion limited curve traces above? And if so, is the data presented at equivalent 1m levels (i.e., 6dB higher)?
Mirror sound source of the surface adds 6 dB SPL with GPM vs. a free air measurement, double the distance reduces 6 dB - hence, GPM 2m equals 4pi 1m.
This has been empirically demonstrated all the way back to 1980, via Mark Gander's original work on the ground plane measurement technique, which I referenced in the video description and was hoping would be read if something was unclear.
Someone conveniently uploaded the PDF here on ASR -> GROUND PLANE ACOUSTIC MEASUREMENT OF LOUDSPEAKER SYSTEM - Gander, AES, 1980. Figure 5 displays the measurement of a speaker suspended in air (essentially 4pi) at 1m distance, figure 8 displays the ground plane measurement at 2m distance; the curves essentially match.
