No. It has active DSP crossover with individual amps driving each component. The kind you are talking about only appears in ultra cheap desktop speakers and very low end monitors.This is one combined 1000w amp for all drivers, yes? Crossover will be after the amp then presumably?
Do you know how many amplifiers and what the spec of each of these are that are driving each individual driver?No. It has active DSP crossover with individual amps driving each component. The kind you are talking about only appears in ultra cheap desktop speakers and very low end monitors.
2x 250W, 1x 500W, as mentioned by the Palmer rep. Class D...Do you know how many amplifiers and what the spec of each of these are that are driving each individual driver?
IMO if they get €600 in gross margin they could be making money. Driver cost for OEMs is much, much lower than it is for consumers. And as I understand it, this is already a big audio business but they just didn't have a monitor line before now. That would put them in a position to buy or manufacture parts at a favorable cost even for a new product line, and maybe even sell decent quantities up front even for a new line. Quantity is really everything when it comes to managing the cost of parts and manufacturing, so compared to a brand like Ascilab or Audio First, an existing, larger business can do things with cost and pricing that are simply out of the question for smaller / newer brands.No matter if Palmer gets 500 or 600€ after dealer percentage, that's still not taking a profit on 3 drivers this capable, a solid aluminum enclosure, potent integrated amplifier and DSP, a rigging system, and so forth.
This is obviously a marketing strategy to boost the brand, with properly priced products to follow later.
Nothing wrong with that, just something to be aware of. Lucky those who are taking advantage while the deal is on.
A proper protocol would be to perform a defined task, a mix, and have it produced with these speakers and another pair. Then have a panel evaluate them on whatever target they think is proper (another can of warms).
That image was indeed what I was thinking of, @Emulator II.Ah yes, definitely taperedThanks for the correction @Emulator II!
Looks like the woofers are mounted at an angle of 177° so a 3° offset, which would mean it will vibrate about 3% as much as an equivalent single woofer @Honken
Why's that?For professional mastering work, the Ultra is likely a suboptimal solution.
High latencyWhy's that?
Might be because the cabinet is die-cast aluminum, the shape might have to do with getting it out of the mold. (Per absolutely no actual experience with die casting!)That image was indeed what I was thinking of, @Emulator II.
But interesting, good to know that the opposing force effect still is effectively... effective then, thanks @staticV3.
But then the question, at least for me becomes, why do that? Is the radiation pattern perhaps more agreeable when mounted this way, or is it perhaps purely a aesthetic choice?
yes, for sure.Mixing a song on a pair of speakers and then mixing the same song on another pair of speakers wouldn’t work, well, unless the mixing engineer has a total memory loss in the time between making those two mixes. The mixing engineer would have learned too much about the mix for his first attempt, which would give him a “head start” for his second attempt that could lead him to either a better mix, or even make it worse second guessing his previous decisions. The better mix of the two attempts will likely, in the end, be the better sounding mix on both pair of loudspeakers.![]()
AFAIK Wiim only use a 10band parametric EQ for room correction, which can introduce phase issues and the latency is pretty high. An arc Studio is cheaper and better in pretty every regard of the goal is a linear phase speaker output.Why's that?
High latency
Useless streaming tech
No differential Line in/out
Useless display and volume knob
No control application for Windows/Mac
Response targets made for domestic environments
Do you know the latency?High latency
Same defeatist attitude expressed 50 years ago when Dr. Toole started his research as to what sounds good to listeners. You won't know until you try. Being dismissive so anything goes subjective opinion is not how you conduct a proper evaluation.Mixing a song on a pair of speakers and then mixing the same song on another pair of speakers wouldn’t work, well, unless the mixing engineer has a total memory loss in the time between making those two mixes. The mixing engineer would have learned too much about the mix for his first attempt, which would give him a “head start” for his second attempt that could lead him to either a better mix, or even make it worse second guessing his previous decisions. The better mix of the two attempts will likely, in the end, be the better sounding mix on both pair of loudspeakers.![]()
I thought your concern was ability to mix on a speaker. If you just want to know what sounds right, research already tells us what that is, in objective metrics.mixing the same song on different speakers is just a show for youtubers, in reality I would test the speakers just by listening to my old projects and starting a few new songs also listening to songs that I know really well. I have good ears![]()
Yes Amir, the ability to mix is my concern,I thought your concern was ability to mix on a speaker. If you just want to know what sounds right, research already tells us what that is, in objective metrics.
With EQ it is possible to make ANY speaker flat to 28Hz at some level. You could take a 1" driver in a soda can and eq it flat to 20Hz, but that doesn't mean it can do it loud enough for you to hear.
