Palmer Orbit 11 Monitor Review and the ones posted in this threadI don't understand. What measure?
Sorry, I still don't understand what you mean by "the Measure is sufficient to derive/interpolate this method."Palmer Orbit 11 Monitor Review and the ones posted in this thread
Apologys, @staticV3, perhaps... is Palmer Orbit 11 Monitor Review Measure, and the ones posted in this thread, sufficient to derive/interpolate your method. You have clarifyed, thank you, by indicateing 'My instructions above are for level-matching', although/perhaps it does suggest the question.... is the Review Measure/s sufficient, doesn't it, perhaps not in all instances?Sorry, I still don't understand what you mean by "the Measure is sufficient to derive/interpolate this method."
My instructions above are for level-matching the Orbit 11 to another playback system for A/B comparison.
If the microphone used for this is frequency response corrected, then in the same stroke you would also measure in-room frequency response.
Whereas a generic microphone would only be good for relative level differences between the two systems.
No, you cannot use just Amir's measurement review to level-match your own playback systems at home.Apologys, @staticV3, perhaps... is Palmer Orbit 11 Monitor Review Measure, and the ones posted in this thread, sufficient to derive/interpolate your method. You have clarifyed, thank you, by indicateing 'My instructions above are for level-matching', although/perhaps it does suggest the question.... is the Review Measure/s sufficient, doesn't it, perhaps not in all instances?
For that, you will have to do some measurements yourself, but this is inexpensive and fairly straightforward.
Thank you, @staticV3, No, the intent was, 'do we even need to compare'? Is the Measure (such as the Palmer Orbit 11 Monitor Review Measure) sufficient? Perhaps not in all instances, and if not then what are all of the Measure Deficiencys, to be aware of them, reasonable?Apologys, @staticV3, perhaps... is Palmer Orbit 11 Monitor Review Measure, and the ones posted in this thread, sufficient to derive/interpolate your method. You have clarifyed, thank you, by indicateing 'My instructions above are for level-matching', although/perhaps it does suggest the question.... is the Review Measure/s sufficient, doesn't it, perhaps not in all instances?
AI bot? Or try different translation software?Thank you, @staticV3, No, the intent was, 'do we even need to compare'? Is the Measure (such as the Palmer Orbit 11 Monitor Review Measure) sufficient? Perhaps not in all instances, and if not then what are all of the Measure Deficiencys, to be aware of them, reasonable?
So funny is this because of legal disclaimer?It gets worse (again, I am just sharing amusing tidbits from the same page of the ORBIT 11 manual):
This product is not suitable for children and persons with limited physical, sensory,
or mental capabilities or lack of experience and knowledge.
https://www.hifishark.com/search?q=Palmer+Orbit+11hello
I am looking for the white pair - EU - anyone?
Cheers
thx already checked
Did you already get them? How do you like them?I bought the white b stocks 2 days back, hope all goes well. Are the analog ins noisier etc? I’ll have to change my Dsp stuffs if I want to use aes in.
not yet, having them shipped from europe to the far side of the earth. 2 weeks i reckon.Did you already get them? How do you like them?
Lots of words without any further informations to what is known.New influencer type of video:
yea like the salad review without acutually eatingLots of words without any further informations to what is known.
Those were the days...Ooops, we're on page #100 now ... how many of these could be deleted that referred to the 'magic orange (tangerine) ring?
