what i mean is just that i found the nobsound volume knob to be much higher quality than the one tested.So would you say that the Nobsound knob is the knob of knobs?
I really must stop this. It can't be the single malt because it's almost gone.... oh
I am about the get this exact thing but in the latest version for switching between AVR und DAC .I've used this one for various projects. Seems to work rather well. If i get a chance I will send it to Amir if he would like to test it.
They look at least interesting. I've got a Chinese knock-off chassis for an expensive Swiss pre-amp. I'm contemplating building a switched preamp with a single output buffer using Neurochrome PCBs and their universal buffer.I'm curious about much more expensive solution
Another polish companyThey look at least interesting. I've got a Chinese knock-off chassis for an expensive Swiss pre-amp. I'm contemplating building a switched preamp with a single output buffer using Neurochrome PCBs and their universal buffer.
It is eye opening to cost out the parts. Difficult to get to a total cost much below $400.
I expect to produce very low distortion and noise, thanks to the attention to performance of neurochrome.
umm.. I mean... it's not too hard to make one, you know?Why wasn't this available during my modding days. Could have easily bought / made power amp kits that didn't have their own volume control.
Voted golfing at first but saw the channel separation isn't perfect, but decent enough so changed to a happy. I don't see how a stereo volume pot can affect channel separation with RCA cabling unless the ground is somehow shared? Then again I don't know how bad a 3.5mm cable affects channel separation so I don't have a baseline to compare with. If a 3.5mm cable does better than this I would go crazy tho.
