All six outputs do not allow an explicit LPF setting, can only set HPF points
There is an "aggregated / derived" LPF for the content sent to sub(s) output (which can variably get mixed with the LFE input)
So, my question is, is that LPF derived from
A. the Front L/R HPF setting
B. whichever output setting is at the highest frequency
C. Some sort of "algorithm" acting on all six settings ?
Eventually I will have all the gear set up so I can actually test this with measurements
so feel free to ignore this if you don't have a ready answer.
I've delved pretty deeply into the manual and past discussions, so if anyone is curious about this unit I'll try to answer any questions I can.
The only flaw I've found so far, is the first factoid above, which just means an external LPF is needed for bandpass use cases, e.g. midbass couplers between Front L/R and trueSub boxen
