- Joined
- Feb 11, 2020
- Messages
- 96
- Likes
- 102
I'm not positive, but I think the trigger output on the 2200 is just a pass-through. Here is what the manual says:
E Trigger Output Jack When more than one Model 2200 is used in an system, this jack may be used to pass the low voltage control signal through to the Trigger Input Jack of an additional Model 2200.
You are correct. I just updated my original post with a new reply that I just got from Outlaw support.
”There is a physical switch for XLR or RCA input, which the 2200 does not have. The trigger output on the 2220 is powered. Whereas, with the 2200, it is not powered. It is simply an in/out connection. This is capable of powering up to 3 amplifiers before the available current from the source device reaches max capability. With the 2220, the trigger out has a separate powered trigger-out circuit. So, a max current availability will not be reached. Thus, more amps can be triggered.”
