No, it's just a different configuration. Radial capacitors are more popular, I guess because they allow for a more densely populated PCB.Are axial better by design?
I was aware that caps need to be secured but hadn't seen zips used before. Like I said I know of zip ties failing due to heat but IME that included UV exposure from the sun. They'll usually fail within a year or two when exposed to the summer sun down here.. Most amps I know use glued caps but Adcom used a nice mechanical method in my GFA-545 II'sI think the caps will go bad around the same time the zip tie goes bad.
I like them versus gluing. I hate replacing components that are glued down.
As noted, they are needed for shipping. They are so heavy they can sheer off their pins if not secured. Or pull out of a cold solder joint.
“Musically pleasing amps generally have the following attributes: voltage-centric devices at their inputs (FETS or tubes), stable open loop performance (they don’t require feedback to keep amplifying), relatively high bias at their output stages.”
Do the Outlaw 2200’s possess any of the above attributes, ie low feedback or high bias at output? Are these attributes that can be measured? Are these attributes even related to an amps “musicality?”
Take a bank of these coupled with a nice prepro.... and you are good.
These look like super nice AMPS for the $/deal. BTW, they are Class AB/G. I read that whole thread -> Audioholics
A poster in the above thread said "Great amplifier... Built by the OE factory (Taiwan) that builds the majority of the Parasound products. He also builds multiple channel amplifiers for distributed audio by SpeakerCraft. We know the factory owner well, he is an experienced audiophile. Over the years we have sourced various amplifier products from his factory... "
https://www.outlawaudio.com/support/faq_2200.html
"A. The Model 2200 utilizes a newly designed (and proprietary) hybrid Class A/B/G circuit. It will provide Class A/B power up to 80 watts (which covers about 98% of most listening situations). Above 80 watts the Model 2200 will instantly shift into Class G amplification.
Q. Why was this approach taken?
A. This approach was chosen because we required that this amplifier be quite compact (less than 2 inches tall). In addition we insisted that the amplifier would not use any fans.
Q. Are there any downsides to this type of hybrid design?
A. The 2200 uses a proprietary A/B G design that does not have any audible downsides. The transition from Class A/B to Class G requires just 2 microseconds (NOT milliseconds) and this transition is 100% inaudible. This was imperative as many other hybrid designs produce audible side effects. Incidentally, at 200 watts the 2200 has less than .05% THD!
Q. What about output transistors and capacitance?
A. For output devices there are a total of six: four bipolar transistors rated at 15 amps each, and two robust power Mosfets rated at 40 amps each. Dynamically into 8 ohms the 2200 will put out 300 watts! In addition it has at its disposal 20,0000 microfarads of capacitance."
Baloney, there's plenty of good ones. There's just a shortfall of SOTA measureing ones at a low price. We still have no idea how the $5 figure ones measure, they haven't been tested.The challenge is in finding a "nice" prepro. There seem to be no good ones available.
If that is the case, you are good to go.Everything sounds great. However I’m curious if the Emotiva is driving enough current thru its output to make the outlaws truly sing. I spoke with Emotiva customer service and they said the PT-100 outputs 2-4 volts.
The Outlaw needs 1.7V via XLR to reach max wattage. So it is fine.Since I am new to separates I’m not too versed in preamp output voltage vs power amplifier requirements.
Im currently running (2) Outlaw M-2200 mono amps. Preamp is an Emotiva PT-100.
Is the PT-100 a sufficient preamp?
Paul at PS audio says this about “musical” sounding amps:
It's not a guitar amp! If it sounds loud enough with your speakers and room etc. then it's fine.
