The power on the label for wall (input) power is an average, not peak value. You cannot really correlate it to the output power of the amplifier. Yes, you used to could, but specs changed and now manufacturers can spec an average rating, often as little as 1/8 the maximum power of the amplifier IIRC.
Who knows? Manufacturers could apply their own standard, so it could mean any of a few possible conditions/combinations.
For the M2200, my guess is, the 600 W is the very "maximum" at very high distortions, or it is the "peak", i.e. average would be 300 W, when driving an 8 ohm resistor load. At rated load, class AB amp (including the Outlaw's class G at the high rail voltage) can have quite high efficiency, may be as high as 70-75%, and transformers can operate at say, up to 125% +/- overload for minutes if not hours.
If you look at the photo shots taken by John Galt, you can clearly see that the PS transformer nameplate says: 53.6 V (based on the higher of the two sec. voltage) and 4.5A, that is 241.2 VA. Based on say 30 W/lb (just one rule of thumb I read for a toroidal tranny), assuming resistor load, 241.2 VA = 241.2 W (again, that's for resistor load only, less for reactive load), the transformer alone would weigh about 8 lbs. According to Outlaw specs, the amp weighs 18 lbs so that sounds about right. That said, its all just guess work..., it is just a question how well can we guess based on available but limited information.
Example of a good Yamaha power consumption spec:
https://usa.yamaha.com/products/audio_visual/av_receivers_amps/mx-a5000/downloads.html#product-tabs
Owner's Manual page 15.
Though far from perfect, I would be happy enough if others (D+M, Pioneer, Onkyo, Anthem, NAD, Arcam etc.) do at least what Yamaha did for their MX-A5000 power amp.
