• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Outlaw 2200 M-Block Amplifier Review
pjug
Starman
My current Outlaws:
8 x 2200 Monoblocks (15 years old)
2 x 2200 Monoblocks (2 days old)
1 x 5000 (1 week old)
2 x 650w 12" subs (10 years old forgot model name)
(Head is a Marantz 8802a)
I Ran a 7.1 setup with the 2200 for 15 years. Tens of thousands of HARD hours mostly to my older large Polk RTI series speakers (Fronts the big RTI12).
In recent years, a Polk LSI center, 4 x Paradigm ADP-590 v5 surrounds.
Now I purchased 2 new 2220's to replace the 2200's for the Paradigm F95's I have coming in a few day.
The old 2200's will go out in my shop in my workout area to power keep powering the Polk rti12's.
One is technically a spare.
The 5000x runs my 4 Paradigm atmos speakers (CI-Elite E-80R).
The point being, I have never had a single issue with the 2200 running them HARD for 15 years, tens of thousands of hours (5 projector bulbs worth of movie time alone without counting music time)
I couldn't be any happier with their products.
Sal1950
The Chicago Crusher
Central Fl
How did you like the 2220 amps? I'm thinking of adding amps for the front L-R channels when I get a new receiver and am torn between the Outlaw 2220 and amp based on Hypex NC502MP.
bogart
Speaking as an owner of the 200 amps, I'm very pleased with their durability and reliability. I've no complaints about them aside from a slight transformer hum that disappears when I close the cabinet doors. The Hypex is doubtless a great product - compact, efficient, cool running. But if I already had the Outlaws I wouldn't change them for it.
I've tried both and the Hypex 502 is clearly the better amp. Whether you notice the difference might depend on your speakers and how power hungry they are. The one thing you immediately notice is the super low noise floor on the hypex class D amps, you can crank the volume and it is silent. The same cannot be said for the Outlaw.
bogart
Without having heard the 502, @thepiecesfit is VERY likely right on the noise floor. The noise floor in my room is not low enough for this to be meaningful in my room in practice, but it's definitely not dead quiet. If you're buying new then I would give Mr. @Buckeye Amps or another reputable Hypex dealer your business.
If you've got your eye on pre-owned M2200 at a good price and budget is a factor, I wouldn't hesitate to pick them up pre-owned based on my quality experience.
pjug
With 87dB speakers I find the M2200 to be more than quiet enough for practical purposes. I have to put my ear right up to the tweeter to hear any noise. Both of mine have quiet transformers as well, no hum unless I put my ear right up to the amplifier case.
Anyone have the M2220 to report how you like the current model?
FWIW the sensitivity/efficiency of my Definitive Technology BP2004TL speakers is 92 dB. The speakers have a nominal impedance of 4-8 ohms.
dfuller
Just joined this forum for this specific thread because I’m hoping you guys may be able to help out.
I just bought 2 outlaw 2200’s to power my towers in a 7.2 setup. Trying to find a 3rd for my center channel with no luck so far.
my issue is this, though....they don’t seem to be powering my towers very well! Before installing them, I had my front towers at +0.5(L) and -0.5(R) to reach 75db at 0 volume on my receiver. The AVR I’m using is a denon AVR-x3400h. Now, after installing these 2200’s via RCA and on the “music” trigger option, I’ve had to turn my L up to +9 and the right up to +6.5 to reach 75db at 0 volume level. I understand the the sensitivity for AVR internal amps is MUCH higher than on a separate unit, but I still feel as though something isn’t quite right here and I can’t find any pre out settings in the denon. Also, my LCR is 2 RTI70 towers and a csi5 center channel.
Thanks in advance for any help with this...
Should only be 1-2dB difference from the Denon accounting for any gain differences. Did you re-run Audyssey? It's generally a good idea to reset and calibrate everything when adding amps.
move just been using REW and an spl meter to do my calibration. I’ll try running audyssey and see what it spits out; I just have very little faith in programs like audyssey especially after all the horror stories I’ve heard. Haha.
Are you setting the appropriate DBFS value for your pink noise? It should be -30 if you are doing speaker calibrations.
ive always just used the test tone built into the AVR when you enter the levels menu. Which, as far as I’ve always understood is pink noise. Idk how I could even overlay my own pink noise track on top of that in the levels menu because the AVR turns off any external audio when I enter the levels menu.
