I refer you back to where I suggested:Well, it depends
What do you mean with "compensate for them"?
And which differences are you considering?
If the target is to decode which words your friends are telling to you, I agree. But for the same analogy, even a speaker of 10€ can serve the purpose, you don't need a 10k setup.
If the target is also to decode the mode/tone on how he tell you the words, probably you won't get if the room are bigger and you are far away. And for the same analogy you need a proper setup, again, better than the previous one.
Go higher in details you want to decode, and you need some pro and quality playback setups.
The fact is: if what you are looking for is deeper (i.e. you decoding target are particularly thin), you reach a point where listening to different setups is always different, so a change in sound make differences for you.
If instead your listening capacity is "limited", you will reach a stable listening at some point.
But in that case, I think you don't need more than a pair of 200€ speakers.
Now, since all of you are expert: if you listen to a track on a pair of speakers and you start to notice that the bass is a bit higher, you are at some capacity level where you will ALWAYS discriminate differences on the bass between different setups, even between 30k ones (because your listening ability is good). Than, it seems you will never got stability in listening to music... it will be ALWAYS different.
Are you saying you don't care about the higher bass differences between setups? Well, you don' need such a setup so, whichever can be ok
That's the only area I'm interested in. An audio system that costs the same as a car is clearly ridiculous. But 200 euros is too low, I think. My own system uses budget and second hand components and would probably come in at about 600 euros. I don't think it could be made from scratch with new components for that unless made in large quantities. It would be more than powerful enough for most living rooms.There is a minimum level of engineering required to do such a miraculous thing as summon the world's finest musicians to your living room on demand, and to do it well i.e. close to neutral. It costs in the region of, say, $1000 up to $5000 - but would be cheaper if millions of people were interested in buying it.
Software is 'free'; electronic circuit boards are cheap; speaker drivers use metal, lots of copper, big magnets, plastic and glue and are heavy; boxes are bulky. There's a lot of parts to put together, and packaging and transporting the finished items won't be cheap. I don't believe there's any magic in exotic materials - it can be done with ordinary materials. It's all in the design and, as I say, a minimum level of engineering.
Would you begrudge spending $1000-$5000 on something as magical as a hi-fi system?
