Otari MX-5050 Review (Reel to Reel Tape Deck)
Accepted, and thanks for correction reg. dbx.
Now we both can sue Apple xD.
Yes but that was at 3% total harmonic distortion!
That’s why I said maybe someone can calculate the SINAD so that we can compare to the measurements of this Onkyo.
The actual record/playback noise level re reference level is going to be roughly minus 60 dB unweighted. The typical distortion is 0.6%. perhaps SINAD can be calculated from that.
I know it can. I’m on mobile device and can’t calculate. That’s why I asked for help.
Nice looking deck. My last reel to reel was a Tascam 80-8 with DBX.
Haha brings some ScFi thinkig in me up.
It was thought to be inpossible to bring the original sound of the beatles mastertapes up again. Endless remastering destroyed them. But with our new concept of quantum time travell backmaster plugin, we give you the original sound of the original 24 track tapes. Master how you like, or go deeper let play Paul a stratocaster. We make it possible. ;)
We may actually need some of that "quantum time travel backmaster" to hear many masters that have been lost before they could be backed up. Enjoy this article from NYT 2019:
Fireproof vaults? Who needs fireproof vaults????? :eek:
30dB shortfall is not exactly approaching is it? And no, dBX never achieved 100dB S/N ratio, not even close. As good as Dolby’s marketing I’m sure studios would have switched to dBX. They didn’t.
dbx (not dBX), achieved 92dB S/N, a 30dB reduction in noise and a dynamic range of 110dB on cassette decks in the early 1980s.
It was well known, plastered all over quality cassette decks at the time and competed directly with Dolby C. Many cassette decks had Dolby B/C and dbx fitted. Plenty of dbx encoded LPs were produced and the cassette decks often had a "disc" button which enabled you to play your records with dbx decoding in real time.
I did the same. I used a Marantz S-VHS machine as I could record 2 hours continuous at very decent quality on one tape. Even the 4 hour LP performance was as good as analogue cassette, even on my Nakamichi, and without all the line-up faff.
However, as soon as Digigram brought out their VX Pocket PCMCIA card, I bought one as it allowed proper non-destructive editing, and 24 bit/48k recording on my then 486/40 laptop.
S.
I used a Sony Beta Hi-Fi VCR to record from the radio for a while. Cassettes on a Denon DR-M44HX sounded good enough but the time limit per side was a pain, plus the VCR could easily be set to record automatically on the timer. I just had to remember to leave the FM tuner on, and on the right station.
Record carefully on better tape, Akai used TDK as reference tapes for type 1, II and IV if IIRC.
(AD/SA/MA/MA-R)
D, AD, ADX/ARX- (less bias for the better tapes)
SA (more bias) SAX (less)
MA, MA-R, MAX-G, (tweak it as you need)
I used mostly Maxell, particularly the XLII and XLIIS. The Sony ones were also good. I tried metal but didn't think it worth the extra cost.
Can you share some sources to those figures? I’m intrigued as even amplifiers then had less S/N ratio than 100dB.
When I was at Abbey Road during 70s we heard about Decca using Dolby with good effect. We were sceptical though. We had tried dbx earlier and was not impressed. Dolby brought two A301s (type A) for us to test.
We then measured the Dolby A on a Studer A80 with EMI tape. We measured 83dB S/N ratio at reference level. We had measured dbx earlier. At 86dB it was quieter.
As a test we chained two device groups without a recorder in between. We couldn’t hear the Dolby unit working but the effect of dbx was easy to hear. We standardised the machine room on Dolby units.
We, above were the engineers and some of the managers of the studio.
I made this thread a while back:
How many tapes fit on this? In FLAC, I guess 200 at least, and for "pennies".
Or, for the A/V hoarders among us https://www.amazon.de/dp/B08JV6PP9B...=geizhals10-21&ascsubtag=Gp7trh3dOCiIngHW53MA
In this aspect, we really live in good times (as long as we don't forget to have a backup).
Or one can go completely careless and "all streaming"...
Depends on the bit-rate. CD/AIFF/WAV uses 10 MB/min, FLAC/ALAC about 6, and AAC/MP3 1 MB at 128k or 2 MB at 256k. Of course you can use (waste) a lot more space by using hi-res.
Were the machines using 200 mil wide tracks or the American 70 mil?
