As best I can tell, all the source impedance does is cause more losses, not change the frequency response. Come back when you can actually bring some knowledge to the conversation.
Not a perfect measurement set her either, but source resistance do affect the SUT frequency response in my measurements with varying source resistance ,
The measurements I have done of my SUTs reveal that they are only fully linear when the source resistance is optimal for the tap.
deviating from this makes then either peak of roll off. I do not believe any SUT can be perfect for 3-40 ohm range,
With an improved set up I get not the same result,but still show differences with different source resistance..
An example is my Denon AU-320 with 3 ohm and 40 ohm taps . With cartridges with these resistances, SUT are very linear 20-close to 100khz, but not with a 10 or 20 ohm cartridge,
I will post a figure when I find it
Edit: Here the 3 and 40 ohm taps run with optimal source resistance
The frequency response is only valid for the conditions the test was done at..
And here with other source resistance, and trying to compensate Zobel RC network etc RS is source resistance
Doing SUT measurements is not easy,,,,,,is not definitely not plug and play , if you want the result to be correct,
