Ortofon ST-70 Moving Coil Transformer Review
Rate this MC Transformer
    Votes: 65 65.0%
    Votes: 24 24.0%
    Votes: 9 9.0%
    Votes: 2 2.0%
This is a review and detailed measurements of the Ortofon ST-70 Moving Coil transformer. It is on kind loan from a member and costs around US $1,500.
Other than fancier footers, the box is ordinary as you see. It is heavy though for its size. Back side shows the simple connections:
Ortofon ST-70 MC transformer Phono Stage moving manget RCA ground review.jpg
There are apparently two version of this unit: A and B. I am not sure which one I have. Here are the specs:
I tested the unit more or less like a black box to characterize its transfer function. It is kind of difficult due to inability to match the impedances but let's see what we have.
Ortofon ST-70 Measurements
I fed the unit 0.5mv input and got this dashboard (default 20 ohm source impedance):
We get a (voltage) gain of nearly 30 dB which should be able to convert a moving magnet phono stage to one that supports moving coil (purpose of the device). At this low level of input, we are essentially noise bound other than mains noise which I could not minimize beyond what you see. There is a distortion spike that is barely visible.
Frequency response is highly dependent on source impedance. Given the choices I have in Audio Precision analyzer, this is what we get:
We are not remotely spec compliant. Even if one matched their spec exactly, how would you do that in real life?
As expected from any transformer, low frequencies is where you see distortion:
I used 1mv to slightly accentuate the effect.
Looking at pure distortion (no noise), we see that the impact is essentially the same as using electronic gain stage in our reference phono stage:
Ortofon ST-70 MC transformer Phono Stage Pure THD vs frequency Measurement.png
Crosstalk is very good in grand scheme of things:
Ortofon ST-70 MC transformer Phono Stage channel separation crosstlak Measurement.png
I ran a test with RIAA inverse EQ active on the input and got this:
Ortofon ST-70 MC transformer Phono Stage THD vs frequency vs level Measurement.png
Without data from other products like it, it is hard to know how well the ST-70 is doing. The frequency response of note, is very poor if taken at face value. I am open to input from members on how to interpret that. Note that I am on a time crunch to send this unit back (will be boxed up today to go out tomorrow). So little time for more experimentation.
The cost is way up there. I would have thought something like this would cost a few hundred dollars.
Matched with a $6,000 Ortofon MC cartridge and an any-price TT this will sound worse than an iPhone. Even at full published specifications. Or am I missing something?
How would you spin an LP in an iphone?!?
If possible measure frequency response with 10 Ohm output impedance, this is kind of typical for low output MC pickups.
I assume you mean input. I can't do that without having to build a resistor network as the AP only goes down to 20 ohm. 20 ohm is still within spec for config A.
Hi Amirm.
Thanks for this interesting review, I had never seen one before.
I have always read the story about transformers for MC cartridges.
I would suggest to suspend the panther, since as you rightly say, you have no other references, so we do not know if for this particular type of products the Ortofon is good or not!
I hope someday you have an opportunity to measure one of John Curl's Vendetta phono preamps.
Clearly you have something amiss with your test setup. Those Lundahl transformers are excellent and should have a wide and flat frequency response.
The loading at the input of your AP maybe is not correct??
Jesus, vinyl is a pricey hobby
Only if you drink the kool-aid. With a Schiit Mani or a Fosi Box X5 coupled with a AT 95ML MM cartridge, you'll be looking at around $300 dollars spent, with SOTA (for vinyl) performance. The expenses, then, will come from the media itself.
And about the transformer, being a very late adopter to the vinyl craze, I never really got the hype around MCs. They seem good and "euphonic" on paper, but in practice the noise levels needed for them, inherent with the high gain on phono amplification, and the huge prices never made sense to me when compared to Moving Magnet solutions. This "high-end" solution from Ortofon proves it further.
In another thread I measured their cheaper st-7 by running comparative cartridge response measurements. Got this for one channel.
Bass roll-off, slight treble rolloff, perhaps slightly increased distortion in the high treble.
The BW spec for the ST-7 is 15 Hz - 45 kHz +0 dB, -2.5dB. Probably doesn't quite get there on the bottom end.
Source impedance of the AP.
You may have config B, as 28.6 dB gain is much closer to 30 dB (spec for B) than 24 dB (spec for A). B needs 10 Ohm source impedance or less.
Yes you are missing something if your ears would prefer an I phone to a top notch TT setup properly.
Hello, The exam you performed seems to correspond to configuration B, which is the default for input impedances < 10 ohms. The measured gain goes in this direction. The user manual is available on the ortofon website. For the AP, configuration A seems more appropriate. To change the configuration, you have to open the device and change the position of jumpers. This may be the reason why the frequency response is so poor.
In any case, the device is quite expensive for what it offers.
Anyone who is listening to vinyl for superior sound quality is doing it wrong, with the exception of superior mixing (lack of compression).
Amir, you really should have checked the manual on this one:
